Old 29th January 2008, 12:59 AM   (permalink)
Default Pull-down resistors
When i am feeding an IC input value from the output of another IC, am I correct in assuming that the input value I am feeding will require no pull-down resistor?
matthewwren is offline
Old 29th January 2008, 01:04 AM   (permalink)
It depends on the output stage of the IC. If it is open collector then you will need a pullup.
Pommie is online now
Old 29th January 2008, 01:50 AM   (permalink)
Pull-up and/or pull-down resistors are also sometimes required if you're changing from one logic family to another, not normal unless you need a special function (e.g., you're working with 74LSxxx TTL and need an analog multiplexer from the CMOS family) and need reliable switching.
By the way, in TTL it's one heck of a lot harder to pull an input down than it is to pull it up, so design your circuits to eliminate inputs from switches and such that require pull-down -- pull up and invert instead.
Dean
R.I.P.
Dean Huster is offline
Old 29th January 2008, 07:36 AM   (permalink)
Yeah, if it's the same logic family and the output is "normal" then you don't need pull-ups or pull-downs. If the output is a open-collector/open-drain you need pull-up resistors. If it is open-emitter/source, then you need pull down resistors.
http://www.interfacebus.com/Design_Translation.html
Wth regards to using a pull-up so that a TTL output can drive a CMOS input, how does that work exactly? I don't quite understand how when the TTL output goes high the pull-up resistor would boost the output just a little bit to allow it to drive the CMOS. It would seem to me that the TTL output would be fighting the pull-up resistor and whichever one could sink more current would flat out win, or there would be a precarious balance.
dknguyen is offline
Led Resistors reach 110C!! dons21 General Electronics Chat 26 20th January 2008 04:14 AM
Pull Up Resistors for PIC Andy1845c General Electronics Chat 8 5th November 2007 02:00 AM
Good Electronic Supply's Sites, Everyone Come On In! :P Electric Rain General Electronics Chat 44 28th August 2007 12:06 AM
7447 with resistors Overclocked General Electronics Chat 5 27th January 2007 01:30 PM
Calculate pullup and pulldown resistors for CMOS ghall426 Electronic Projects Design/Ideas/Reviews 5 21st December 2006 01:19 AM
