I am having touble finding out what is wrong with a circuit I have designed. So I have gone out and bought a multimeter to check what voltages are going in and coming out of the various IC pins. I just wanted to ask if there are any gotchas i should know about regarding the use of multimeters on circuits?
Many fuse in the digital multimeter in my college were blown because many of them measure the current as the voltage.
__________________ bananasiong | |
| | #3 | |
You can avoid the problems bananasiong is talking about by always measuring voltage, rather than trying to measure currents in your cct. You must break the circuit to measure current, however voltage can be measured across components. Measure the voltage across a resistor, etc., then use Ohm's law to find the current. You should also know that most multi-meters cannot, reliably, measure AC. | ||
My multimeter comes with an rs232 adapter and software, so I am guessing this would cover everything an oscilloscope does too, or are oscilloscopes more reliable and have extra functions?
| | #5 | |
| | #6 | |
Would you care to elaborate? JimB
__________________ Experience is directly proportional to the value of the equipment ruined. | ||
| | #7 | |
Points to be aware are : - AC and DC measurements, - Current on one side, Voltage, Resistance, Frequency, Continuity Test on the other side, - Special Functions like: Diode test, Caps Measurement and Temp - Multimeter Setup. - use of proper terminal leads ( Pin, Alligator ... ) and the best point of start is to read the Manual.
__________________ Its what your friend in Your mind, what you in your friends mind | ||
| | #8 | |
Why, do you have a meter which will handle AC well? | ||
| | #9 |
| | #10 | |
Lefty
__________________ Measurement changes behavior | ||
| | #11 | |
I looked in the manual for my old 8012a (Fluke) and according to that, AC is good up to 200V at 50 kHz with a + or - 5% error. It is true RMS too. Thanks! | ||
| | #12 | |
| | #13 | |
A Simpson 260 was good to around 150KHz on ACV. Some of the lower-priced Fluke multimeters started falling off at around 1KHz. Better and/or newer DMMs will have higher AC frequency capability, but still not as good as a true AC voltmeter, e.g., the Hewlett-Packard 400E (10MHz, average-reading) or 3400A (10MHz and true rms). Of course, some oscilloscope models will measure up to 1GHz real-time while most run around 100MHz or more. However, the scope does not give you the accuracy and/or precision of a DMM. Satisfy your needs wisely! Dean
__________________ Dean Huster, Electronics Curmudgeon Contributing Editor emeritus, "Q & A", of the former "Poptronics" magazine (formerly "Popular Electronics" and "Electronics Now" magazines). R.I.P. | ||
| | #14 |
Thanks for your help ppl ... the multimeter diagnosed my problem just fine and my circuit is working as intended now.
| multimeter, question |
| Capacitor Charge/Discharge question | ThermalRunaway | General Electronics Chat | 25 | 12th August 2008 05:48 PM |
| Multimeter Question | raphaelriv | General Electronics Chat | 15 | 6th July 2007 05:11 PM |
| High speed data logging question | cubdh23 | Micro Controllers | 3 | 19th August 2004 12:54 PM |
| PBX question | waqar | Electronic Projects Design/Ideas/Reviews | 0 | 30th March 2003 07:21 PM |
| LED multipack / multimeter question | daviddoria | General Electronics Chat | 6 | 15th February 2003 11:39 AM |
