Hi, Whats the best way to bump the 12v rail to 13.8? I do need to keep the amps (20, 30 and 40) Thanks for your time. Eric | |
what is the power source at this moment???
The 12v source is a ac to dc converter switching power supply.
| | #4 | |
You realize you are going to lose a bit of amps right? Power in always greater than power out, and you are turning some of it into higher voltage so that means a little less current. Is there a reason you need it at 13.8V and not 12V though? I would imagine most things would run fine like that. I think 12V would be the nominal voltage for a 12V SLA battery and 13.8V is the peak voltage for the same battery pack. | |
| | #6 |
hi, As the amps are pulled (about 6 amps) the voltage tends to drop to around 11.4v I am using it to power my chargers. They will error out at times complaining of loss of voltage due to this drop in to 11.4. Is there a "POT" I can turn? Or do I need to add something? How much amp drop would I be looking a you think? | |
| | #7 |
If I understand you right, your power source can't provide enough power. YOu need another power source. YOu can't make extra voltage and current from nothing. A 12V supply that could actually supply 20A doesn't need to be bumped up to 13.8V. Your local hobby store probably sells some power supplies. http://www.fcsurplus.ca/shopping/sho...Power+Supplies I use the PS26KX. | |
| | #8 |
is it typical for a 12v power supply to drop to 11.4 volts at 6 amp pull? Or is this a regulator problem? I understand you cant get it form nothing but I have seen talk about putting a load on different voltage rails to increase the 12v rail or atleast make it stronger. Like adding a sand bar to the 5v+ to increase the 12v. | |
| | #9 |
you probably need make your own power booster for the big current you listed.
__________________ F.N. | |
| | #10 | |
Are you talking about placing a capacitor between the rails to supply the peak current demand? That might work if the peak currents are small enough for a short enough time and the converter is able to handle the average current over time, but not the peak currents. | ||
| | #11 | |
then, if the output is taken after an isolating diode in series to the +ve lead, the voltage will drop on load , while on open measurememt with a DMM it might show 12V.
| | #12 |
while underload I used my MM to check.
| | #13 | |
Torben | ||
| | #14 | |
| | #15 | |
20A max on the 12v rail | ||
| 12v, 138v, power, supply, switching |
| Switching power supply issue. | dbtoutfit | General Electronics Chat | 41 | 25th March 2008 04:21 AM |
| Got a new EVBoard How do i supply power to it? | cubdh23 | Micro Controllers | 2 | 3rd August 2007 10:39 AM |
| Using a computer power supply WITHOUT a computer? | grrr_arrghh | General Electronics Chat | 13 | 4th April 2007 01:15 AM |
| need help with power supply parts very info... | rodniepr | General Electronics Chat | 0 | 6th April 2005 04:33 AM |
| Power supply/ current supply design | inkedallusion | Electronic Projects Design/Ideas/Reviews | 1 | 17th December 2002 02:10 AM |
