my name is Nick and i'm new here! a friend of mine from here helps me so i can learn electronics! but many things he says i dont understand them so here i am! i want to bias a transistor so i can light a simple led! i know ohms law and how transistors work but i cant do it! please tell me stepbystep what to do!!!!!!!!!!!!!!!!!!!!!
This is a good site. http://web.telia.com/~u85920178/begin/bias-00.htm
__________________ If you aren't afraid of life then you aren't paying close enough attention. | |
| | #3 | |
__________________ Its what your friend in Your mind, what you in your friends mind | ||
ok it helped! now who is going to tell me whats the difference between Vebo (emitter-base voltage) and Vbe (base-emitter voltage)?
Vebo is when the base-emitter of a transistor is reverse-biased. Then the transistor is turned off very quickly. When the base-emitter voltage of a transistor is zero then it turns off pretty quickly but not as fast as when the base-emitter has a reverse voltage. Most silicon transistors have a max allowed reverse emitter-base voltage of only 5V to 7V. Vbe is when the base-emitter of a transistor is forward bised and the transistor is turned on. The forward voltage is about 0.6V for a low current to 1.5V for a very high current. Most little transistors have a Vbe of about 0.7V at a reasonable current.
| | #6 |
I got these results is my transistor biased correctly? Transistor 2n3904 Resistors: 5.8K base, 385Ω collector. hFE=202 Vcc=14V Ib=0.0026A ? Vbe=0,79V Vce=2.18V across led=2.05V Ic=30.7mA 0.0026x5800=15.8 15.8+0,79=16.59V | |
| | #7 | |
| | #8 |
heres a photo
| | #9 |
No 'biasing' required then, it's just a switch - just bang enough current in the base to make sure it's turned hard on.
| | #10 |
what about the above calculations why i'm getting wrong results? also the 385Ω resistor gets hot!!!!!!!!!!!!!!!! my friend cant explain whats going on with the Ib and we get such results and about the hot resistor he says that is smaller than the power dissipation about 0,1W and needs bigger than 1/4W is that correct? | |
| | #11 |
The transistor is biased with a base current of 2.3mA and has a collector current of about 30.1mA. The transistor is turned on hard so its collector voltage is about 0.1V.
| | #12 |
The 385 ohm resistor has about 11.9V across it so it dissipates about 368mW which is far more than a little 1/4W resistor can dissipate. Where did your arithmatic fail?
| | #13 | ||
__________________ Its what your friend in Your mind, what you in your friends mind | |||
| | #14 | |
0.0023x5800=13.34 13.34+0,79=14.13V but our indication is 0.0026A and not 0.0023A!!! what was that 0.1V at the collector? i dont understand! the voltage at the collector-emitter is 2.18V | ||
| | #15 |
The emitter is at 0V. The base is 0.8V when it has 2.3mA. So the 5800 ohm resistor limits the base current to (14V - 0.8V)/5800= 2.3mA. The emitter is at 0V. The transistor is turned on hard so its collector voltage is 0.1V. Therefore its Vce is 0.1V. The Vce would be 2.18V if the transistor did not have enough base current to turn on properly.
| bias, transistor |
| Transistor Biasing | UTMonkey | General Electronics Chat | 16 | 14th November 2007 08:11 PM |
| Transistor Switch | Digger7 | Electronic Projects Design/Ideas/Reviews | 14 | 7th June 2007 04:12 PM |
| Discrete Pulse width Modulator... | Rajagopal87 | General Electronics Chat | 8 | 16th August 2006 06:25 AM |
| Transistor Operation | ElectroMaster | Electronic Theory | 1 | 23rd June 2006 05:26 PM |
| transistor amplifier frequency | mstechca | Electronic Projects Design/Ideas/Reviews | 1 | 9th June 2003 08:48 PM |
