Old 23rd January 2008, 09:32 AM   #1
Default High Voltage, high frequency?!
Hei there.
I`m wondering, whats the differences of sending 4000V 50 Hz through a long cabel, and 4000V 400Hz through the same cabel, the load on the end is not to much..
jdahl is offline
Old 23rd January 2008, 10:16 AM   #2
Default High voltage, high frequency
Hi jdahl,
the only difference is the fact, that transforming the high voltage to normal 230V less iron is required for the transformer at higher frequencies.
In aviation the generators normally supply a 400Hz voltage which is transformed to 24 or 48V feeding all aviation electronics and hydraulic acutators thus saving weight.
On land lines high voltages are used to reduce the current flow resulting in less losses.
Boncuk
Boncuk is offline
Old 23rd January 2008, 10:17 AM   #3
Well... it's easier for you to send 50Hz because your mains supply is already at that frequency and you would just step up the voltage with a transformer...
I'm sure there would be some interference caused on devices by sending 400Hz through a long cable... It would help if it was shielded.
Edit: If you do decide to switch it at 400Hz, you baisically have a switchmode power supply on your hands, and you need to reconvert it back to AC... it would be easy to keep it a square wave but then you are complicating things if you want to filter it out back to a sine.
What is a joule per second?
erosennin is offline
Old 23rd January 2008, 10:50 AM   #4
Thanks guys,
The weight issue exsplains it... there are limited space at the end, so thanks for the help.
jdahl is offline
Old 23rd January 2008, 04:23 PM   #5
The real question is why do we use 50/60Hz and not 400Hz on the mains. I think it's historical and a legacy issue. Not sure though
dknguyen is offline
Old 23rd January 2008, 04:43 PM   #6
Isn't it due to the required speed of the generators?.
Old 23rd January 2008, 04:47 PM   #7
Ah, yeah that could be it. Those massive generators probably have a speed limit.
dknguyen is offline
Old 23rd January 2008, 04:58 PM   #8
They could always add more poles which brings us back to it being legacy.
Pommie is offline
Old 23rd January 2008, 05:12 PM   #9
But could you add 8 times as many poles? - I suspect it's probably a question of a happy medium between the different alternatives.
Old 23rd January 2008, 05:18 PM   #10
It's cheaper, it's already there, everything uses it!
dknguyen is offline
Old 23rd January 2008, 06:14 PM   #11
Forgive me for not googling this, but I have often wondered how the mains are kept so accurate as far as frequency goes. Isn't the frequency all in the speed the generators are turning?
I have wondered how the US settled on 60Hz mains. Why not a round number like the rest of the world?
This message transmitted on 100% recycled electrons
Andy1845c is offline
Old 23rd January 2008, 06:22 PM   #12
There are many countries who use 60Hz.. not just the US.. many who use 50Hz... and they are both "round" numbers.
Optikon is offline
Old 23rd January 2008, 06:32 PM   #13
Apart from the historical and a legacy issue, there are tecnical reasons:
>>>> The inductive reactance of the long power lines (and capacitive reactance in the underground cables):
With 400 Hz the series inductive reactance is higher (reactance = inductance x 2 x Pi x frecuency), giving more voltage drop.
And the paralel capacitive reactance is lower, which gives more leakage current.
>>>> 400 Hz is well into the audio spectrum, so a 400 Hz grid (and its harmonics) should cause more interference in "plain old analog" telephone circuits.
E Cerfoglio
Buenos Aires
Argentina
ecerfoglio is offline
Old 23rd January 2008, 06:38 PM   #14
The mains' frecuency is the timing reference of the "electical clocks":
Once upon a time they were sincronous motors driving a mecanical clock,
Nowadays there are lots of electronic clocks that use the mains cero crossing as a reference: standalone clocks, microwave ovens, VCRs, etc.
The frecuency may have a little short term drift, but the utilities correct it in the long term comparing an "electrical clock" with a good time reference.
E Cerfoglio
Buenos Aires
Argentina
Old 23rd January 2008, 07:54 PM   #15
Could the higher 'skin effect' (higher line resistance) of using 400hz on very long power lines Vs 50/60 hz be a factor in selecting the lower frequency for power distrubution?
Lefty
Measurement changes behavior
Leftyretro is offline
frequency, high, voltage
High Frequency Reed Switch KeepTheFaith Datasheet/Parts Requests 0 19th December 2007 01:41 PM
PIC18F2620 input high voltage only 2V..? MrNobody Micro Controllers 3 14th December 2007 02:29 PM
High Voltage Indicator?? ZIGGY_DAN General Electronics Chat 4 20th June 2006 01:13 PM
Making High Voltage George L. Electronic Projects Design/Ideas/Reviews 11 15th March 2006 04:16 PM
Having problems with pic16f872 cjgalway1000 Micro Controllers 0 7th April 2004 03:39 PM
