What do you call a circuit that switches from household 110 to batteries when the electricity goes out (and back to the mains when the electricity comes back on)? Is there a proper name or description for this type of circuit? | |
it could be called a transfer switch
__________________ If you don't have a planet, what good are gold bars? want to contact me directly? gmail gordonthree check out my project website: http://projects.dimension-x.net Favorite numbers: 09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0 Last edited by justDIY; 22nd January 2008 at 10:38 PM. | |
UPS. United parcel Service. Uninterruptible Power Supply. I spelled it wrong on the other website.
| | #4 | |
How about a "dropout switch" or a "changeover switch?" I am very familiar with pre-packaged UPS systems. You give me an idea. Could I just steal the major components of an off-the-shelf UPS and just replace the connected battery with one or more car batteries connected in parallel? I don't see why not as long as I don't exceed the capacity of the inverter built in... | ||
Some UPS's have a tiny battery (that is why you want a bigger one) that lasts for only a couple of minutes so a computer can shut down. Then it also has tiny heatsinks. It will smoke if you tried a huge battery and have it operating long enough to get very hot. Its charging circuit also might croak.
| | #6 | |
to a car battery and then to an inverter. I can then run the fans off the inverter full-time. This is hard on all of the equipment involved though. I would rather not wear the battery charger and inverter out so soon. Seems like it could even be a safety issue somehow to me. Anyway, what is a simple switch/relay configuration I can build to solve this problem? Can you point me to any articles or threads about it? I'm more than happy to read so you don't have to type...I'm very new to electronics and don't quite know what I'm looking for... Could I use some type of relay with an AC power supply, that just switches the fan input over to the battery/inverter system on the other contacts? If so, what type of relay is this? Last edited by downplay; 22nd January 2008 at 11:17 PM. | ||
| | #7 |
Maybe I can use a "double throw, double pole, break-before-make" relay to make the transfer. If I power the switching with a transformer on the mains, when the mains power failed, it would then switch over to the battery/inverter supply. Does this make any sense? Would it work? If so, where do I find such a relay? | |
| | #8 |
because the batteries in UPS are so expensive to buy, you can find ENORMOUS UPS (6u x 19" x 3' or 4' deep) on ebay. These are designed for server farms ect, where they are required to keep LOTS of servers alive for reasonabley long periods. I would have thought you could hack one of these. I used a UPS (dead batteries, £10 collect only) as the basis for my power supply in my works van. I needed 'clean' power for my computers, but only had a 2-stroke petrol generator. I connected that to the ups and my computers, so that the power was filtered by what was probably a very well made (and expensive) filter when the unit was new. Even with the dead batteries, there was enough power in them to allow the ups to do its thing, and covered the 5mins or so it took to re-fuel the generator. for example i just found 2x 3000VA sitting at £5.50 What sort of current are we talking about? If its heavy current then you would need a contactor, if its low current then any DPCO rated for the current would be fine. You wouldnt want much in the way of filter caps in your transformer, as it could delay the coil de-energising, meaning that your 'emergency' circuit wont kick in immediatly. | |
| | #9 | |
I need about 250 watts for about 4 hours (slightly overestimated for safety) at 110 watts. As best I can calculate, a UPS style system with a marine battery on a charger should work great. I think a battery powered timer should be able to handle the trickle mode of a battery charger. So, I want a DPCO instead of a DPDT? Is it the "stable off position in the centre" that prevents some problem in my circuit? Would they be good for 250 Watts/2.3 amps at 110 volts? Would a device like the one at the link below work? http://www.newark.com/86H6705/electr...questid=119348 | ||
| | #10 |
DPDT/DPCO is same thing i think, 2 poles each with 2 positions, the stable state would be the n/c contacts. You would wire your backup mains power through the n/c contacts, and your normal mains power through the n/o contacts. Wire your 'load' to the common contacts, and use a transformer plugged into the normal mains for the relay coil. where is mains, the circuit uses mains, when it fails, the coil de-energises and connects the 'load' to the backup mains. 2.3 amps would be no problem at all for a suitable relay that relay you linked to is a bit big and industrial, there are many smaller, and still capable relays. You will probably find 12v relays easier to power as 12v wall warts are a lot easier to find (and cheaper) | |
| | #11 |
Can you suggest any online suppliers for such a DPDT or DPCO? Yes, 12 volts is much more common. I really have no idea where I can find such a relay that I can solder or otherwise attach wires... Last edited by downplay; 23rd January 2008 at 06:25 AM. | |
| | #12 |
| | #13 |
I have been using 300 watt (or so) ups with car batteries for a long time. Here in the US Virgin Islands the power goes out a lot. It's a comfort to have a fan and a lite when the power is out. I get the ups for free, toss the gel-cells and run a wire out to the battery. The ups keeps the battery up, and I've only had one drop dead. Audioguru is right about heat sinks and overloading the unit. I now look for units with fans. I have a Powerware Personal 1000 I'm trying to revive, but can't find schematics. It's blowing the internal 30 amp fuses on the 30 volt side.
| | #14 |
Hi downplay What do you wan't to run on it ???? keep in mind that UPS normaly don't handle peak surges that well so if you have some inductive loads that needs a big starting current to run you still might have a problem that it can not handle it Robert-Jan | |
| | #15 | ||
| call, circuit, switches |
| Junebug INT2 problem | futz | Micro Controllers | 9 | 15th November 2007 03:32 AM |
| LCD Template Code For PIC16F84A (Help) | Peter_wadley | Micro Controllers | 23 | 4th April 2007 04:47 AM |
| pic16f877 tmr0!!! | procos | Micro Controllers | 5 | 9th May 2005 01:04 PM |
| Chip talk | dreamproject | Electronic Projects Design/Ideas/Reviews | 8 | 2nd April 2005 08:24 PM |
| Motor control interface | dreamproject | Micro Controllers | 0 | 31st March 2005 04:48 AM |
