hello,
i must to build an energy deterctor using a diode in the square law region. i must to project this circuit using a bat32 diode but it's a month that i try to build it but with no results. Someone can help me? The circuit is very simple, it's composed by a ac voltage generator to 6GHz frequency a diode in serie and a low pass filter at the end. if you kwon a better configuration please answer to this post thanks If someone wanto to help me and he need more information please post here the question in attachement i propose one configuration that i tryied to implement. |
That circuit should work OK.
Possible problems/queries: The diode is faulty? What DC bias are you applying? Are you sure that the 6Ghz signal generator works OK? How is the circuit built? On a board with a solid ground plane I hope, NOT on veroboard, breadboard etc. You mention 6Ghz, try it at a low frequency such as 1 Mhz and when you get good results, try increasing the frequency. JimB
Experience is directly proportional to the value of the equipment ruined. |
thank you for the answer please help me |
What did you use for inductors? How did you measure the bias current?
Roff
He hasn't used any inductors or measured any current! He has just played with a computer game (simulator). JimB
Even with a sim, you need inductor values. A current source in the wrong direction will give some outlandish DC volts, or perhaps the sim won't run. Last edited by Roff; 1st February 2008 at 04:58 PM. |
biased detector.cir *Esempio di curva I-V .probe .model BAT62/SIE D(IS=120N RS=200 N=1.04 XTI=1.8 EG=.68 + CJO=.35P M=.14 VJ=.4 FC=.5 BV=40 IBV=5U TT=25P) ********** INGRESSO ********** V1 1 0 SIN(0 0.01 6G) ********** CAPACITA ********** * SEPARA LA POLARIZZAZIONE * * DAL SEGNALE APLLICATO IN * * INGRESSO. * ****************************** C1 1 2 1000p ********** RF CHOKE *********** * SEPARA L'ALIMENTAZIONE A RF * * DA QUELLA IN DC * ******************************* L1 2 4 100n V2 4 0 0 ********** DETECTOR ********** D1 2 3 BAT62/SIE ********** FILTRO PASSABASSO********** * - LA RESISTENZA FISSA LA BANDA * * - LA CAPACITà TIENE LA CARICA * ************************************** C2 3 0 100p R1 3 0 500 .TRAN 0 1NS .PLOT TRAN V(1) .end in output i find the same signal in input attenuated. nothing similar to the effect of the square law region thanks for the answer |
I cannot really comment on your Spice set-up, I am not familiar with simulators.
What output are you expecting from the circuit? What you should get is a DC voltage which is in some way proportional to the peak value of the RF input. JimB
I can post the sim a little later. The second half of the Super Bowl is about to start. BTW, 1ns is much too short for the sim time. That's only 6 cycles of the carrier, not nearly enough time to allow the capacitors to settle, etc. You probably need to run it for at least 10usec. |
Here ya go.
thank you for the simulation result. can i ask you the value of the bias V1? thank you |
This is good training for using a simulator but what practical purpose this has is beyond me.
At 6GHz every connection is an inductor and capacitor and a simulation package doesn't account for this. If you try building this on veroboard you will fail.
The trick is to build it so you don't add unwanted components (inductors, capacitors) to the circuit. As you said, Veroboard is not the way to do it, but I have breadboard material that consists of a 0.1" grid of plated-through holes, with ground plane surrounding them on one side, and I'm sure you could successfully build it on that. I couldn't test it, because I don't have a 6GHz generator. |
I tested the circuit and it work very well also in the reality. now i have an other problem, i tried to used an amplifier and an ADC but the circuit works very well when i use 1 volt input signal but the i put a 0.1 volt signal the input of the amplifier became negative(it's v(4) in the picture below) if you can, help me please. i post the cir file and the simulation output of the 1 volt input signal and 0.1 volt input signal biased detector.cir *Esempio di curva I-V .probe .model BAT62/SIE D(IS=120N RS=200 N=1.04 XTI=1.8 EG=.68 + CJO=.35P M=.14 VJ=.4 FC=.5 BV=40 IBV=5U TT=25P) .inc ./AD8009.cir .inc ./AD8611.cir *EXP( {v1} {v2} {trise_delay} {tau_rise} {tfall_delay} {tau_fall) ) *Vname 12 0 PULSE(0V 0.01V 0S 0.5nS 0.5nS 100nS 200nS) *V1 - initial voltage; V2 - peak voltage; TD - initial delay time; Tr - rise time; Tf - fall time; pwf - pulse-wise; and Period - period. Vname 12 0 EXP(0V 0.1V 0S 0.5nS 0S 40nS) Vd 13 0 sin(0 1V 4GHz) ****** INGRESSO ********** Epulse 1 0 VALUE = {V(12)*v(13)} *V1 1 0 SIN(0 0.7 6G) ********** CAPACITA ********** * SEPARA LA POLARIZZAZIONE * * DAL SEGNALE APLLICATO IN * * INGRESSO. * ****************************** C1 1 2 1000pF ********** RF CHOKE *********** * SEPARA L'ALIMENTAZIONE A RF * * DA QUELLA IN DC * ******************************* L1 2 5 33nH C4 5 0 10nF R1 5 6 50kOhm V2 6 0 1V ********** DETECTOR ********** D1 2 3 BAT62/SIE ********** FILTRO PASSABASSO********** * - LA RESISTENZA FISSA LA BANDA * * - LA CAPACITà TIENE LA CARICA * ************************************** C2 3 0 10pF R2 3 0 500Ohm R_LPF 3 4 1kOhm C_LPF 4 0 10pF ******** AMPLIFICATORE AD8009 ******** R21 27 0 10 R20 28 27 1000 R25 28 0 100 Xamp 4 27 100 0 28 AD8009an VCC 100 0 5V ******** ADC D8611 ****** Xcomp 28 99 100 0 0 0 7 8 ad8611 Rout 7 0 50 Rx 98 99 1k Vcomp 99 0 1.8V .TRAN 0 1uS .PLOT TRAN V(1) .end |
| Interfacing Energy meter | vaayuputhran | Electronic Projects Design/Ideas/Reviews | 2 | 6th January 2008 01:53 PM |
| "Miracle Tube" produces more Energy than put in (Yes, another one...) | Analog | Chit-Chat | 7 | 21st September 2007 12:58 AM |
| Free Energy FAQ/Guide V2.0 | TheVictim | Alternative Energy | 0 | 20th July 2007 05:55 PM |
| Evanescent Coupling?!? A new way to transfer electrical energy? | Analog | General Electronics Chat | 20 | 11th June 2007 02:46 AM |
| damping | niga | General Electronics Chat | 11 | 7th June 2005 07:04 AM |
