| hello all, i was looking for an op.amp scheme to subtract and amplify. I'm not asking for a complete circuit. I'm just looking for suggestions, for example what op.amp configuration i have to use, and so on. As input i have a 125Khz, 200Vpp signal. It can vary sometime from 200 to 199V. I need to convert this variation into 0-> 1V variation, with a subtracion, then i would like to have the variation amplified as 0-> 5V. Actually i have available a TLC272 powered 0 and 5 V. Thanks , angelo Last edited by spectrum; 20th January 2008 at 12:34 PM. | |
| We are confused! You have a 125khz signal that has a voltage of 200 p-p. It is 200 volts and some times 199 volts. You want 199 volts to equal 0, and 200 volts to equal 1 volt. This 0 to 1 volt, is it 125khz AC or do you want DC? Then you want the 0 to 1 volt amplified to 0 to 5 volts. Is 5 volts the only low voltage supply around? Is it OK to go from 199/200 to 0/5 volts direct? The 0/5 volts is it DC or 125khz AC? How much current will be pulled from the output? How accurate 1%, 5%, 10%? How temperature stable? 1%/degree C? I need more information! What are you doing? | |
| ok, i try to reformat the question as simple as i can. I have an information in a 125Khz carrier, 200Vpp. The information is the Vpp that change between 199 and 200Vpp. Let's cut the signal with a diode, and work only with the pulsed positive part. If easier to work with pulsed only positive part, after a diode, so 100 and 99,5V are now the levels. I need to have this information whit a -99,5 offset, a kind of cutting the wave, so i would get 0 and 0,5V information. I don't have other DC sources thant 0 and 5V. That's all i need for now. thanks angelo | |
| To see the difference between 100 and 99.5 is a problem. Electronic parts are not perfect. If I built a subtract 99.5 volt circuit using 5% parts it might subtract 99 volts or 94 or 104. How many cycles of 125khz are there per bit of information? One cycle at 99.5 volts =0 and one cycle at 100 volts =1 ? 100 cycles at 99.5 =0 and 100 cycles at 100 = 1? This makes a big difference on how to do this! The answer could be very complex or simple. I need so see the big picture. E-mail me if you don’t want to tell everyone what you are really doing. | |
| Hi. Is there any reason you can't rectify this through a Schottky diode (0.2V to 0.3V drop) then run it through a two resistor (precision types, 1% or better)voltage divider? Do you need a buffer or instrumentation amplifier, or can you just use a high value (50K - 100K or higher) resistor in the input as a limiter? Of course if you run this through a rectifier bridge you will have a 250KHz signal. If this signal is entirely above the zero point, i.e., all positive, the diode(s) is(are) unnecessary. Inquiring minds will ask. 'Luck in your project. kenjj
__________________ All my pencils *used* to have erasers! | |
| Voltage Protection Circuit | jnnewton | Electronic Projects Design/Ideas/Reviews | 15 | 20th January 2008 11:02 AM |
| Power Supplies | jack23 | General Electronics Chat | 3 | 9th October 2007 05:11 PM |
| Voltage | ElectroMaster | Electronic Theory | 44 | 8th August 2007 06:35 PM |
| Current limiting Help PLZ | Frosty_47 | General Electronics Chat | 32 | 24th July 2007 04:51 PM |
| measuring transconductance(gm) | walters | General Electronics Chat | 24 | 6th February 2006 09:50 AM |
