Old 18th January 2008, 03:13 PM   (permalink)
Experienced Member
Thunderchild is just really niceThunderchild is just really niceThunderchild is just really nice
Send a message via MSN to Thunderchild Send a message via Yahoo to Thunderchild
Default making pcb's
where can I get pcbs made ?
is it worth getting my own equipment ?
my site:www.simons-photography.com
http://rushdenrotaract.org.uk
see also
http://www.bigstockphoto.com/account...fid=m2URATYch5
http://www.redbubble.com/people/simonsphotography
Thunderchild is offline   Reply With Quote
Old 18th January 2008, 03:24 PM   (permalink)
Experienced Member
chemelec is just really nicechemelec is just really nicechemelec is just really nice
Many different places.
That depends on you needs.
Do you need many different ones?
How often?
How complex of boards?
Can you generate the actual artwork to do your own?
Only you can really answer your question.
I No Longer accept Private Messages on here.
All Emails to me Must Contain the Word \"Electronic\" in the \"Subject Line\"
or they go Directly to my Junk Mail Folder.
Email me at: chemelec@hotmail.com
Website: http://www3.telus.net/chemelec
chemelec is offline   Reply With Quote
Old 18th January 2008, 03:27 PM   (permalink)
Experienced Member
1. yes a pcb per project basically
2. don't know
3. normal stuff pic projects, and general analog stuff mostly single layer
4. I think so I presume there are programmes ? one of the cinese pcb companies had a program to download perhaps I could print off from that ?
see also
Old 18th January 2008, 04:03 PM   (permalink)
Experienced Member
2. don't know
3) Pic projects can sometimes result in pretty small traces. Can be a problem.
4) Most of this Software is Only good top the company that supplies it.
But home made is probably a lot cheaper for you. If you can do it.
I make all my own boards.
Old 18th January 2008, 04:05 PM   (permalink)
Experienced Member
ok so what equipment do I need to make my own ? how much might it cost me ?
see also
Old 18th January 2008, 05:01 PM   (permalink)
Experienced Member
HarveyH42 is a name known to allHarveyH42 is a name known to allHarveyH42 is a name known to allHarveyH42 is a name known to allHarveyH42 is a name known to allHarveyH42 is a name known to all
There are quite a few threads on making your own PCBs with links photos and more, if you don't mind using the search function. If you already have a laser printer, I'd suggest the 'Toner-Transfer' method. I've been making my own boards this way for the past couple of years with good results.
HarveyH42 is online now   Reply With Quote
Old 18th January 2008, 05:13 PM   (permalink)
Experienced Member
hm I have inkjet
see also
Old 18th January 2008, 05:30 PM   (permalink)
Experienced Member
mvs sarma is a name known to allmvs sarma is a name known to allmvs sarma is a name known to allmvs sarma is a name known to allmvs sarma is a name known to allmvs sarma is a name known to all
Send a message via MSN to mvs sarma Send a message via Yahoo to mvs sarma
you may perhaps getit printed else where on a laser printer andremaining process you can do at your pemises.one or two boards and project and lab works, it is better done by you. and if a design goes for bulk production, you may order out. Chemelec has rightly suggested. and HarveyH42 has told the TTS methods.
Regards,
Sarma.
mvs sarma is offline   Reply With Quote
Old 18th January 2008, 05:44 PM   (permalink)
Experienced Member
picasm will become famous soon enough
If you don't have a laser printer, you can use a photocopier instead.
Samsung do cheap laser printers if you need one, but check that toner refill kits can be obtained as a proper replacement toner cartridge can be more expensive than the printer!
The current Samsung model is the Ml-2010 and costs about £43. A toner refill costs about £7 off ebay.
picasm is offline   Reply With Quote
Old 18th January 2008, 06:15 PM   (permalink)
3v0
Moderator
3v0 is a splendid one to behold3v0 is a splendid one to behold3v0 is a splendid one to behold3v0 is a splendid one to behold3v0 is a splendid one to behold3v0 is a splendid one to behold3v0 is a splendid one to behold
It is worth having a laser printer.
First check around for a HP Laserjet IV. Often then can be found for free if you know where to look. They are excellent printers. You can get the commonly needed repair parts.
So far I have done all my boards. If you want fine traces then the special transfer paper is the way to go. Search threads for Pulsar or PulsarPro. In the UK Press&Peel blue may be easier to find. I have no experience with it.
3v0 is online now   Reply With Quote
Old 18th January 2008, 06:48 PM   (permalink)
Experienced Member
hm I have inkjet
Perhaps , inkjet (color may be) is more of your daily need bing a photography expert. I saw some of your phtographs at the site. Really NICE
So may be few prints of PCB lay out be done on inkjet and then xeroed with dar print on the Glossy paper, and it might serve your needs.
Regards,
Sarma.
Old 18th January 2008, 06:53 PM   (permalink)
Experienced Member
well suppose I can get a laser they are not that expensive. so what else do I need ? what is pulsar ? I'll make a search
see also
Old 18th January 2008, 07:06 PM   (permalink)
Experienced Member
Please see this site
http://www.ronlin.co.uk/
Regards,
Sarma.
Old 18th January 2008, 07:55 PM   (permalink)
3v0
Moderator
PiulsarProFx.com sells the starch based transfer paper. As I understand it there is no one in the UK distributing it at a reasonable price if at all. That may have changed shince I last checked.
Visit the pulsarProFx website for details on the process even if you do not use their paper.
I like to use a liminator rather then a clothes iron. They make the process easy. Pulsar has a hint of faking it if you do not want to buy a laminator.
Old 18th January 2008, 09:49 PM   (permalink)
Experienced Member
Tarsil is on a distinguished road
Lightbulb
I tend to like photoresist method. U can make fine PCB's at a low cost.
For the exposure u can use a "black light" tube (the blue-ish ones used in disco)...pref a cheap one (emits more UV).
U can use a Inkjet printer (just buy some inkjet film). About the special board u can buy them or make them with a photoresist spray.
If is too complicated.....most of the times is the wrong way.
Tarsil is offline   Reply With Quote
making my own pcb's jrz126 General Electronics Chat 10 4th October 2004 09:26 PM
Problem with making PCBs at home? Fu manchu Electronic Projects Design/Ideas/Reviews 14 21st May 2004 01:28 PM
Tutorial: Making PCBs Devil_H@ck General Electronics Chat 8 13th May 2004 03:57 PM
For those of us making UV PCB's Crofty Electronic Projects Design/Ideas/Reviews 0 5th May 2004 10:32 AM
Making PCB's /w Transparencies - help! Richie086 Electronic Projects Design/Ideas/Reviews 1 12th June 2003 02:27 PM
