hm
well its not urgent I'll try and peg on with strip board
I AM the exeption that disproves the rule in many ways but the rules still apply (unfortunately) my site:www.simons-photography.com http://rushdenrotaract.org.uk see also http://www.bigstockphoto.com/account...fid=m2URATYch5 http://www.redbubble.com/people/simonsphotography |
Yes I had...but i sprayed 3 layers (dry-spray-dry ...) with the spray kept at the same distance so i could get a ~2inches line. The PCB came OK.
Since then i buy coated boards (like 2$..~8x4 inches) Now i'm trying to get some polyvynilic alcohol, make my one coating solutions and use the "dipping" method.
If is too complicated.....most of the times is the wrong way. |
I have recently been using the toner transfer method to make double sided boards...
I use injet transparency plastic... after printing, line it up and staple it on one side... Then I slide the copper board inside and iron it... I found that after ironing it, cooling it quickly seems to help in getting the toner to release of the plastic... |
This discussion has morphed into a generic discussion of DIY PCB making.
A lot of information on the subject can be found by searching this forum and others. In short: You can use toner transfer or photo resist. If you choose toner transfer and can obtain pulsarPro or P&P blue transfer paper use it. They work well. At under 2 cents US a square inch it is not worth you time to try anything else. If you live in an area where you can not get either of these products you might think about setting up a company to import them for resale. If anyone wants to talk about a process that has not been discussed many times it would get my attention. |
I get those mags for free. Even if I buy them (like 3-5$/issue) it's OK Geting a Playboy .......for the paper...
I am not stuck on pulsar paper for any other reason that it works well, every time. Nearly goof proof. Can you post a board you created that shows the ability/limits of the process. |
| making my own pcb's | jrz126 | General Electronics Chat | 10 | 4th October 2004 09:26 PM |
| Problem with making PCBs at home? | Fu manchu | Electronic Projects Design/Ideas/Reviews | 14 | 21st May 2004 01:28 PM |
| Tutorial: Making PCBs | Devil_H@ck | General Electronics Chat | 8 | 13th May 2004 03:57 PM |
| For those of us making UV PCB's | Crofty | Electronic Projects Design/Ideas/Reviews | 0 | 5th May 2004 10:32 AM |
| Making PCB's /w Transparencies - help! | Richie086 | Electronic Projects Design/Ideas/Reviews | 1 | 12th June 2003 02:27 PM |
