| I need to detect the presence (with a TTL logic level output) of two separate power supply voltages, +7V and -7V. Is there a dual comparator IC I can use that will give me a TTL output for a negative/positive comparison? What would the input circuit look like for this? Would a LM311 be a good choice? Would you pull up the output of the comparator to +5V? The only thing I know about analog is: "Ground is where you grow Roses!" Thanks in advance for the help. David
__________________ Save the Earth - its the only one with Chocolate! | |
| The LM311 can be cranky and difficult to stabilize. I would suggest the LM393 Dual or the LM339 Quad. Make sure that any circuit you design observes the requirement that the input signals be within the common mode range of the device. You can satisfy the requirement by powering the comparators from +9V and -9V to measure values in the range [-7V .. +7V]
__________________ We never have time to do it right; but we always have time to do it over. | |
| Here ya go. Connect the ground pins from your +/-7V supplies, and from the 5V logic supply, to the ground (the little triangles) on this circuit. | |
| Thanks for the quick reply, I noticed in Ron's schematic that the power to the LM339 is single ended to +5V, am I reading that correctly, or do I need to power it with +/- 9V as "PapaBravo" suggests? Again, thanks for the circuit, I'll try it today. David
| Hello! I tried the circuit, and have the following results: +7V - on at 3.6V, off at 4.0V -7V - on at 2.9V, off at 3.3V Any ideas on how to troubleshoot the circuit? Thanks. David
-7V - on at -2.9V, off at -3.3V ? If the supply voltages are present, the outputs of the comparators are high (+5V). If they're not present, R8 and R7 force the output low. Placing the threshold voltages at about 3 or 4 V with hysteresis gives you some margin for errors caused by tolerances+noise. | ||
| You are correct of course, I was not looking at it properly. I understand the circuit now, and I indeed need it only to detect the presense (or absense) of +/-7 volts. Thanks again for the great circuit idea. David
| Voltage | ElectroMaster | Electronic Theory | 44 | 8th August 2007 06:35 PM |
| boost converter overshoot / undershoot | justDIY | General Electronics Chat | 17 | 21st December 2006 05:50 PM |
| Voltage Clamp | ThirtyTwo | General Electronics Chat | 41 | 11th August 2006 05:05 PM |
| I am not getting ripple voltage at the output | dar2525 | General Electronics Chat | 3 | 14th July 2005 03:21 PM |
| Voltage controlled amplifier | Jimbo | Electronic Projects Design/Ideas/Reviews | 2 | 20th October 2003 01:25 PM |
