Old 14th January 2008, 11:36 AM   (permalink)
Default Switching On/off 240v Via 26vdc
Hi
First post my electronic no how is close to zero so can any one help.
I have a 240v feed which I need to switch via max 26vdc is there a way I can do this amps would be 20 A max?
Nick
nickk1 is offline
Old 14th January 2008, 12:59 PM   (permalink)
A simple relay?.
Nigel Goodwin is online now
Old 14th January 2008, 01:08 PM   (permalink)
how would I wire it and what one, size make would I be looking for.
As I said no how limited.
Nick
nickk1 is offline
Old 14th January 2008, 02:07 PM   (permalink)
You need to tell us exactly what you're switchig, and exactly what the control signal is.
Old 14th January 2008, 02:25 PM   (permalink)
If you use a SPDT (Single Port Double Throw) It would have five connecting points, VDC , GND , NO , NC and C. When you apply voltage across VDC and GND , NO and C points become short otherwise NC and C are short.
So if you connect your connect your device through C and NO, It will work when you apply VDC to your relay.
And remember, to be on the safe end connect an appropriate diode across VDC and GND to avoid Back EMF
Khizer Naeem Mughal
IIUI
Cry_Wolf is offline
Old 14th January 2008, 02:39 PM   (permalink)
What this is for is turning on and off a gas solanoid valve in a welder the valve is rated at 240v 50hz.Power going to the valve is 240v ac, I want to controle it i.e turn it on / trurn it off via the controle trigger in the tourch which gives out 26vdc this supply comes from a transformer. Sorry dont know what you mean by controle signal.
Nick
nickk1 is offline
Old 14th January 2008, 03:40 PM   (permalink)
The 26V is the control signal, you mention it's DC, do you know what current it can provide?.
Presumably the 240V valve doesn't require a lot of current?, so you just need a 24V relay (24V is a standard voltage), and wire it as above.
Old 14th January 2008, 04:05 PM   (permalink)
Please forgive my stupidity but do I use a 24v dc relay or a 240v ac one?
Nick
nickk1 is offline
Old 14th January 2008, 05:05 PM   (permalink)
The relay 'coil' is 24V DC, the switching contacts are rated for 240V AC.
A relay is essentially a mechanical switch (the contacts) moved by an electromagnet (the coil).
Old 14th January 2008, 05:07 PM   (permalink)
Question
What size diode would i use to stop EMF?
NICK
nickk1 is offline
Old 14th January 2008, 05:13 PM   (permalink)
NICK
What makes you think you need one? - and a diode doesn't do that.
Like I asked before, what actually feeds this 26V?, and what is is supposed to feed?.
Old 15th January 2008, 10:24 AM   (permalink)
Smile
Ciruit working thanks for all your help
Nick
nickk1 is offline
Linear Vs Switching Regulation. Overclocked General Electronics Chat 35 14th January 2007 05:25 PM
QT113 sensor IC- 240v switching spondootre Electronic Projects Design/Ideas/Reviews 4 11th December 2006 03:25 PM
Zero Signal audio switching gtrdude General Electronics Chat 12 12th November 2006 08:28 PM
Simple PNP switching problem DirtyLude Electronic Projects Design/Ideas/Reviews 41 8th October 2006 03:20 PM
Ultra low power switching circuit & DC to DC converter t fastenjaw Electronic Projects Design/Ideas/Reviews 15 16th November 2004 10:57 PM
