Old 14th January 2008, 06:25 AM   (permalink)
Default Calculating torque
Greetings!!!
Anyone know the correct way to calculate a motor's torque? To lift up 1kg thing by using a stepper motor...
thx..
ultimatekiller is offline
Old 14th January 2008, 06:35 AM   (permalink)
YOu need to know the lever arm's length (or the radius of the wheel). Basically you need to know the distance between where you want the force applied and the center of the output shaft (of the motor or the gearbox, whichever is last stage in the transmission).
THen you just go:
T = F x L
THat is the MINIMUM torque you need to HOLD the load STILL against gravity. If you know the acceleration required then you can do more. (ie. use F=ma, and then use your calculated F in the first equation.)
dknguyen is offline
Old 14th January 2008, 07:40 AM   (permalink)
THen you just go:
T = F x L
can u introduce me any good website for me? with examples? thx
Old 14th January 2008, 07:54 AM   (permalink)
Roman Black did some torque testing on his site below is the link http://www.romanblack.com/stepper.htm
Cheers Bryan
bryan1 is offline
Old 15th January 2008, 05:45 AM   (permalink)
Cheers Bryan
thx yao... this is a good website!!!
Old 16th January 2008, 01:24 AM   (permalink)
At low speeds a stepper motor's torque is approximately equal to its holding torque. It is all downhill from there. As the speed increases the torque decreases until you reach a speed where the motor stops altogether as the step pulses continue with reckless oblivion.
In a DC motor there is a Torque Constant K-sub-T which when multiplied by the current gives the torque. By Newton's second law this is equal to the moment of inertia, I, of the rotor times the angular acceleration in radians/sec/sec. If you know three of the four you can compute the remaining one.
We never have time to do it right; but we always have time to do it over.
Papabravo is offline
Electronic Torque Limiting dknguyen Robotics Chat 17 6th March 2007 12:05 AM
torque of a stepper motor bananasiong Electronic Projects Design/Ideas/Reviews 42 29th April 2006 09:09 AM
Torque of stepper motor- different user Kappa707 Electronic Projects Design/Ideas/Reviews 8 27th April 2006 03:22 AM
Torque of the motor sarang1_in Electronic Projects Design/Ideas/Reviews 13 19th July 2005 06:51 PM
DC motor torque fabbie General Electronics Chat 7 12th April 2005 05:19 PM
