Old 23rd January 2008, 11:52 AM   (permalink)
Hellwo everyone,
since you are addressing the charging issue could you please give me some information on how to estimate the minimum and maximum current for charging and also the right volatage I am planning to charge a 12 V 12AH battery like scooter batteries,
any good links to estimate these ?
adnan_m_s is offline
Old 23rd January 2008, 03:57 PM   (permalink)
Originally Posted by adnan_m_s
Hellwo everyone,
Typical charging current is around 1/10 Capacity.
so about 1.2 Amps for your 12AH Batterys.
I No Longer accept Private Messages on here.
All Emails to me Must Contain the Word \"Electronic\" in the \"Subject Line\"
or they go Directly to my Junk Mail Folder.
Email me at: chemelec@hotmail.com
Website: http://www3.telus.net/chemelec
chemelec is offline
Old 26th January 2008, 03:34 AM   (permalink)
is it possible to get a larger and enhanced image of the powersonic charger, and also what is the amperage of the output? i am looking for one about 3 amps out, and the voltage output of the transformer. the battery is 12volt 18Ah, cycle use charge voltage is 14.4-15.0volts and initial current is less than 5.4 amps. if i can get one about 5 amps, than all the better.
Every little bit counts! It works with money, and it works with electronics!
bunghole is offline
Old 27th January 2008, 01:42 AM   (permalink)
Do you want a "larger and enhanced image" of the schematic or the charger? The charger is rated at 1.25A out. If you went with a larger current transformer, and rectifier, and LM350, you could get 3A out. There is also the possibility of adding external pass transistors to the Powersonic charger to boost it to 5A: http://www.national.com/mpf/LM/LM317.html
Ken
KMoffett is online now
Old 27th January 2008, 04:51 AM   (permalink)
Ken
I believe an LM338 will also get you 5 amps out in the same circuit.
chemelec is offline
Old 27th January 2008, 10:12 AM   (permalink)
thanks. i might try this idea but i am still searching for a charger to see what i can find. would a 3amp lead acid battery charger be okay to charge a sealed lead acid battery?
because i found this and it seems to suit my needs:
http://www.uoguelph.ca/~antoon/gadgets/labc2.htm
i edited the schematic to what i actually need. (P2, R5 and S1 are removed, so the charger is only for 12v)
bunghole is offline
Old 27th January 2008, 05:14 PM   (permalink)
As it says on the Schematic, This charger is "Not for use on Gell Cells".
** I am quite sure it is also Not good for use on Sealed Lead Acid batterys for the same reason.
That Extra High Current can cause problems in these batterys, resulting in premature battery failure.
chemelec is offline
Old 27th January 2008, 07:47 PM   (permalink)
Try this site and he has a good document to speak and detailed circuitry towards the end of the downloadable pdf file.
http://www.geocities.com/vk3em/sla-c...a-charger.html
Regards,
Sarma.
mvs sarma is offline
Old 31st January 2008, 08:19 AM   (permalink)
i could use an lm350k, which is 3amps (battery rated at 5.4)
bunghole is offline
Old 31st January 2008, 04:30 PM   (permalink)
As I told you before: Typical charging current is around 1/10 Capacity.
"So for a 5.4 A/H battery, your charge rate should be about 540 mA".
Charging at 3 amps will distroy the battery.
chemelec is offline
Old 1st February 2008, 08:14 AM   (permalink)
sorry about that part...i forgot to say that that battery is 18Ah and has a 5.4 amp max charging current
bunghole is offline
Old 1st February 2008, 02:57 PM   (permalink)
Charging at 3 amps will destroy the battery.
I feel that the SLA batteries can't be frequently charged at a rate more than prescribed. Generally we may have to follow manufacturers recommendations as regards charging rate, let it be 10, 16 or 20 hr rate. Perhaps due to urgency we may charge at higher rare but such attempts must be minimal for better life of the battery.
Regards,
Sarma.
Old 2nd February 2008, 05:16 AM   (permalink)
what current is suitable for a 20hr charge rate? (now i know what the '20HR' means)
bunghole is offline
Old 2nd February 2008, 05:39 AM   (permalink)
I meant charging at a current =AH capacity/20 as 20hour rate. However, please study the instructions contained on the battery regarding normal and fast charge rates and let us follow them, as the manufacturer knows better about its products.I feel charging current need not exceed AH capacity/16 or AH/20. for best possible life of the battery.
Regards,
Sarma.
Old 2nd February 2008, 07:11 AM   (permalink)
here is where i bought it:
http://www.jaycar.com.au/productView...Max=&SUBCATID=
it was on special to.
the picture is the best i could get from my camera.
bunghole is offline
constant voltage, constant current Lead Acid Battery Charger Erwin_Macaraig Micro Controllers 1 4th October 2008 01:26 AM
Battery Charger with auto shut-off feature hardcore misery Electronic Projects Design/Ideas/Reviews 134 12th February 2008 09:20 PM
Lead Acid battery charger manojp01 Electronic Projects Design/Ideas/Reviews 5 29th January 2008 06:17 PM
Battery charger help... dieselmo34 Electronic Projects Design/Ideas/Reviews 14 18th December 2006 06:30 PM
Battery charger for mobile phone Motorola 2PAC Mafia General Electronics Chat 0 4th October 2005 04:20 PM
