I have a sensitive analog/RF circuit (1.2V supply, draws max. current 300mA) and for testing purposes I need an adjustable 1.2V (+- ~100mV) supply voltage. I would prefer on-board voltage regulation, but I cannot find any adjustable linear regulator configuration that could produce such a small output voltage and I don't dare to use switching converters (due to noise issues, right?). There's no on-chip voltage regulation, just some bypass capacitor. What I'm left with is to take raw DC-supply connection to the chip? If so, do I need to consider some kind of on-board LC-filtering, or just place some bypass capacitors (both close to the chip and power connector)? I'd appreciate any help with this.. |
You could use a zener reference diode driving a power OPA. Place a variable resistor across a 2.5Vref and adjust the input to a non inverting OPA. set it for +/-0.1V on 1.2V Do you follow that.?
Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ |
Could you please explain this in more detail cause I'm not quite sure what you mean.. thanks! =)
If you look at the data sheet for the LM317 voltage regulator, it can be set to regulate at voltages between 1.2 & 25 Volt.
For 1.2 don't insert R1 and put a short circuit in place of R2. That will give you around 1.2 ~ 1.25 Volt. Let us know if you have any problems.
Len |
LM317 was actually my first approach, but it had problems getting below 1.25V. I really would like to have quite accurate tuning range around 1.2V, or at least from 1.2V to 1.3V.
You may want to consider still setting the LM317 up as an adjustable regulator and putting a diode on the output terminal which will drop less than one volt, but then you could adjust the output to where you want it.
The forward voltage drop will vary a little with the diode. You could use a 1N4001 or a 1N5817. The 1N5817 is a schottky diode so the voltage drop would be lower.
The great thing about electronics is unlimited ways to do the job. The only limit is one\'s imagination. I generally think my way is best. Show me a different way. I have an open mind. |
Diodes are a bad idea as they'll ruin the regulator's good regulation. The voltage can be reduced all the way down to 0V by adding an op-amp and a few resistors.
http://www.electro-tech-online.com/e...er-supply.html http://www.electro-tech-online.com/a...f?d=1160858956
Will this help? It's quick and dirty, and a short to GND on the output will destroy the TIP31, but it is short-term stable, and has good source and load regulation.
voltage across the diode will be stable.
I'm always up for designing things in a clever way....but sometimes I get lazy and just look for a chip
Look at http://www.linear.com devices: LT3021, LT3021ES8-1.2 Also national semi have a few ultra low noise regulators: LP38501-ADJ for example goes down to 0.6V @0.1% line regulation to 1000mA It does seem that many regulators have an internal reference of 1.2-1.25V, but there are so many nowdays its just easier if you have access to internet distributors. The previous answers covered the DIY approach quite well, and if you do RF I'm sure you have enough knowledge to carry it out. GOod call with avoiding the switchers, I've been stung recently on an RF project by them....nothing filters them completey. Just wanted to add something different. Blueteeth
Inconsistency is the key to flexibility! |
![]() This has already been discussed before. http://www.electro-tech-online.com/g...regulator.html
If so, you could supply a small negative voltage to the adj terminal of the LM317.
Len |
| ULTRA clean 9VDC Power Supply Project | Peter_wadley | Electronic Projects | 42 | 30th July 2008 09:50 AM |
| Home made PCB's | markland556 | General Electronics Chat | 27 | 22nd February 2008 02:30 PM |
| Voltage | ElectroMaster | Electronic Theory | 44 | 8th August 2007 05:35 PM |
| Voltage reference with a zener diode | Futterama | General Electronics Chat | 7 | 28th January 2006 08:35 AM |
| voltage regulation for fan | kvos | Electronic Projects Design/Ideas/Reviews | 3 | 13th March 2003 04:41 AM |
