+ Reply to Thread
Page 1 of 3
1 2 3 Last
Results 1 to 15 of 42
Thread: Resistor color code
  1. #1
    positronicle Newbie
    Join Date
    Aug 2007
    Location
    Hot Springs
    Posts
    23
    Default Resistor color code
    I would appreciate any feedback you might have, on an interactive resistor color code program I have recently put together. It does require the shockwave plugin, in order to work, though.
    Thanks.
    http://m.domaindlx.com/tobbler/
  2. #2
    Torben Excellent Torben Excellent Torben Excellent Torben Excellent Torben Excellent Torben Excellent Torben Excellent Torben Excellent Torben Excellent
    Join Date
    Oct 2006
    Location
    B.C., Canada
    Posts
    2,469
    Quote Originally Posted by positronicle
    Thanks.
    You asked for it, so I'm gonna pick nits. But to start: it's very well done.
    o It's visually gorgeous, if a little clean.
    o It appears to work.
    o I would like a way to just input a value, or. . .
    o . . .a way to go back. Say I'm at red and I just want to go to brown. Currently I have to cycle through all the other colours to get back to brown.
    o I got it to work on Linux using wine and ie6. Firefox on Linux didn't have access to the Windows stuff it needed. Could it be done in a more open format which would allow more geeks-in-training to use it?
    Like I said, picking nits. Overall it's a good job.
    Disclaimer: This review is worth exactly what you paid for it.
    Torben
  3. #3
    3v0
    3v0 is offline
    3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent
    Join Date
    Jul 2006
    Location
    USA
    Posts
    6,464
    Blog Entries
    11
    Most modern resistors are SMDs which are too small to use color code banding.
    The value of learning them is questionable.
    But as Torben said, nice work.
  4. #4
    aljamri Okay
    Join Date
    Jun 2006
    Posts
    278
    nice work and very good application, but an additional points would make it much better:
    * the other way round, to input the value and get the color code.
    * 4 band Resistor color code
    * a toggle indication to tell whether this is a standard value or not.
    Its what your friend in Your mind, what you in your friends mind
  5. #5
    positronicle Newbie
    Join Date
    Aug 2007
    Location
    Hot Springs
    Posts
    23
    Thanks for the input, guys. I've now uploaded a newer version to the site, one which allows for reversing the order of your selection. I'll probably see about adding a way to input a value manually, next. By the way, I also compiled that same version as a basic ".exe"(shockwave not required), and uploaded it in a 3mb Zip file, in case anyone wanted to try that instead. You can download it by selecting "free", waiting a short while(usually about a minute), and then entering a security code.
    It's located here:
    http://rapidshare.com/files/82296083/reziztor.zip.html
  6. #6
    Join Date
    Oct 2006
    Location
    B.C., Canada
    Posts
    2,469
    It's located here:
    Cool beans. The .exe works fine under wine, too.
    More suggestions: I would second the call for a way to show whether the current value is standard or not; even better might be a toggle to disallow non-standard values altogether.
    Also, from a usability point of view, a Help icon or button of some kind would be nice. That said, it's not like the thing has the most complex interface ever but currently you only get instructions once and they then disappear. Even better would be to obviate the need for instructions at all with UI elements to click on for the value up/down.
    Looking good!
    Torben
    [Edit: Oh yeah--about the Flash stuff. Flash is fine for cross-platform work, but the x-director MIME type for the .dcr file doesn't appear to work on Firefox or Opera except on Windows. Probably needs .NET or something; I'm not interested enough to find out. Perhaps it's just another option in the 'Save as. . ." or "Export as. . ." or whatever it is you use to output your project for publishing to the web.]
  7. #7
    Brian Hoskins Good Brian Hoskins Good
    Join Date
    Dec 2007
    Location
    South Wales, UK
    Posts
    229
    Nice work!
    You spelt colour wrong though. There's a u in it <Damned American spelling>
    Brian
  8. #8
    pfofit Newbie
    Join Date
    Nov 2006
    Location
    Eastern Canada
    Posts
    48
    You allow the possibility of a black band on the first place on the left which is a no no. Although it won't appear in reality, someone, not in the know may try looking for that sequence.
    <Black- red -red -gold> relays 200 ohms 5%
    cheers
    If it was easy, then anyone could do it.
  9. #9
    wmmullaney Good wmmullaney Good wmmullaney Good
    Join Date
    Dec 2006
    Location
    USA
    Posts
    368
    Quote Originally Posted by aljamri
    Here is one I like,
    http://www.dannyg.com/examples/res2/resistor.htm
  10. #10
    positronicle Newbie
    Join Date
    Aug 2007
    Location
    Hot Springs
    Posts
    23
    Hi all, I just thought I would let everyone know about an "easter egg" in the newest version at the site.
    In order to reach it, you must set the resistor to 420 ohms, at 10% tolerance, and then click a certain screw(upper right) on the unit.
    By the way, unlike Flash, I don't think Adobe has written a shockwave plugin for linux yet. Probably using Wine, is about the only option for viewing shockwave from Linux, as of right now.
  11. #11
    crusty Okay
    Join Date
    Nov 2007
    Posts
    215
    awesome job! i guess i can forget "bad boys only race young girls but violet gives willingly."
  12. #12
    Gaston Okay
    Join Date
    Jun 2004
    Location
    USA
    Posts
    468
    don't you have the o and r backwards crusty? : )
  13. #13
    Join Date
    Oct 2006
    Location
    B.C., Canada
    Posts
    2,469
    Yeah, so it would appear. Oh well.
    Torben
  14. #14
    Dean Huster Excellent Dean Huster Excellent Dean Huster Excellent Dean Huster Excellent Dean Huster Excellent
    Join Date
    Feb 2003
    Location
    Harviell MO USA
    Posts
    956
    "Most modern resistors are SMDs which are too small to use color code banding. The value of learning them is questionable."
    Most modern electronic devices use integrated circuits, too. No point in learning about transistors, diodes and that silly Ohm's Law stuff.
    Or the observation could be, "Oh, as soon as electronic devices started using SMT, all the other thru-hole technology just disappeared?"
    Dean
    R.I.P.
  15. #15
    crusty Okay
    Join Date
    Nov 2007
    Posts
    215
    Quote Originally Posted by Gaston
    yep that's it, been awhile since i've used it.
+ Reply to Thread
Page 1 of 3
1 2 3 Last
Tags for this Thread
