| i am constructing an igbt driver using this part http://www.farnell.com/datasheets/86257.pdf in the schematic, it uses an opto isolator. i have got the basic circuit to work (by grounding the in pin grounds the output voltage). i have also got an opto isolator to work (by passing a 10khz signal through it), but when i integrate the 2 systems nothing works... sigh! any ideas? | |
| The input should be below 0.8 volts for a low. The opto may not be able to pull the input that low. The pullup resistor should pull up to 4.2 volts with a 1uA load. So the question is; what is the high and low voltage on the input. Do not pull more than 10mA from the reference voltage. | |
| Driver circuit for IGBT module | controlp | Micro Controllers | 4 | 7th August 2006 06:00 PM |
| Opto Isolated RS232 - TTL Help | samltd | Electronic Projects Design/Ideas/Reviews | 4 | 30th June 2006 12:45 AM |
| Help with Opto High Side Driver | William At MyBlueRoom | General Electronics Chat | 3 | 9th May 2006 08:24 AM |
| 200mW isolated DC-DC PS: driver circuit for transformer | Dave#2 | Electronic Projects Design/Ideas/Reviews | 1 | 3rd February 2006 05:01 AM |
| Here is a list of semiconductor prefixes. | TPS | Datasheet/Parts Requests | 0 | 21st December 2003 08:24 PM |
