Old 7th January 2008, 03:03 PM   (permalink)
Default Quick question about Rheostats?
hi guys
im tryin to figure out what type of 2 pin Rheostat i would need to variy the voltage of a 12v 15w bulb from 6v - 12v.
what type, ohm risistance, etc exactly would i need?
im not doing anything complex so i would NOT really want to use anything else i.e digital controllers
TuscanT is offline
Old 7th January 2008, 03:56 PM   (permalink)
Originally Posted by TuscanT
hi guys
It can be done, BUT its not very elegant.
A 15W lamp at 12V passes a current of 15W/12V =1.25Amp.
To drop from 12V to 6V [ie; 6Volts] at say 1.25A = 4.8R
The power dissipated by the resistor would be 7.5Watts,, it would be HOT.
Expensive:
http://uk.farnell.com/jsp/search/bro...+resistor&Ntx=
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is online now
Old 7th January 2008, 04:55 PM   (permalink)
I see
are the any other in-line (2pin) simple alternatives that i can have analoge/manual control to vary resistance?
TuscanT is offline
Old 7th January 2008, 05:00 PM   (permalink)
I see
Do you have any power transistors or regulators in your odds/ends box.?
Eric
PIC tutorials:
Old 7th January 2008, 05:05 PM   (permalink)
i believe so. the source of power is a car 12v battery. the power is regulated if i recall correctly via the relays on the car.
TuscanT is offline
Old 7th January 2008, 05:19 PM   (permalink)
Between the 12V car battery and the lamp you need a power transistor, mounted on a heatsink. The base voltage of the power transistor would be controlled by a standard variable resistor.
Do you have any experience with transistors?
Eric
PIC tutorials:
Old 7th January 2008, 09:36 PM   (permalink)
A transistor is DEFINATELY the way to go. so simple to integrate. I would suggest a NPN Power transistor. If you want to continue, lemme know and I will draw you a schemmy of it to help you.
Krumlink is offline
Old 7th January 2008, 11:28 PM   (permalink)
aside from building simple subwoofer crossovers and i only have basic knowlage of transistors etc. any schematic is welcome. all i want as aformentioned is just to have and inline variable manual control of the bulb (varying the value between 6v-12v)
TuscanT is offline
Old 7th January 2008, 11:42 PM   (permalink)
There you go. Just connect the rheostat any way. It has no polarity.
Krumlink is offline
Old 8th January 2008, 12:57 AM   (permalink)
Hi Krumlink,
The transistor will have the full supply across its base-emitter diode when the variable resistor is turned up in your circuit. SMOKE!
Mine is an emitter-follower.
audioguru is offline
Old 8th January 2008, 03:23 AM   (permalink)
o.k
so what exact components/value/type etc would i use to do this
TuscanT is offline
Old 8th January 2008, 04:20 AM   (permalink)
o.k
Well a 2N3055 power transistor would work fine and is an easy cheap transistor to find. However like any power transistor, you will have to mount it to a heat sink of sufficient size.
As far as the rheostat I would prefer to see a fixed resistor, to limit the maximum current draw, wired to the pot for decreasing brightness from that set maximum. I'm sure someone here can 'spice' simulate the resistance values for you.
Lefty
Measurement changes behavior
Leftyretro is offline
quick question [next 30 minutes] masfenix General Electronics Chat 3 14th December 2007 05:27 AM
Quick Eagle question zevon8 General Electronics Chat 9 30th May 2006 07:24 PM
Quick transistor question Dan East General Electronics Chat 8 20th April 2006 01:54 AM
quick max232 question jrz126 General Electronics Chat 4 21st December 2005 08:31 PM
quick interrupt question evandude Micro Controllers 2 11th August 2004 09:59 PM
