Old 6th January 2008, 10:45 PM   (permalink)
Question LM339 Sink to Source Converter???
I am building a secret project, codename: KAPTR v1.0, and The Comparator in it can only sink current, not source it, so therefore I need to figure out in order to get the H Bridge working for it how to convert the Sink (negative output) into source (positive output), essentially I need to invert the negative signal. Do you have any ideas on how I can approach that? I was thinking of using a PNP Transistor on the LM339 outputs and have that output a Positive signal, but would that work if I then used that as a positive output?
Krumlink is offline
Old 7th January 2008, 12:30 AM   (permalink)
Yes. The open collector output stage of the LM339 can be used to turn on a PNP stage. Current flows from the supply to the emitter to the collector to the motor. The base needs to be pulled up to the motor supply and a limiting resistor from the base to the LM339 output will set the maximum current through the motor.
We never have time to do it right; but we always have time to do it over.
Papabravo is offline
Old 7th January 2008, 01:49 AM   (permalink)
Thanks a lot, was testing it and I put one on there for testing, and It works great. Thanks a lot. I just have to mount a few boards and I will post more soon
Krumlink is offline
Old 7th January 2008, 11:09 AM   (permalink)
Use an opamp rather than a comparator - perfect cure in one easy step!.
Nigel Goodwin is online now
Old 7th January 2008, 07:01 PM   (permalink)
Well then it would make the H bridge (that I am using) stall, because it would turn the high side and low side on at the same time, causing a stall and a short circuit, a easy way to destroy it
Krumlink is offline
Old 8th January 2008, 01:09 AM   (permalink)
So your H-Bridge is badly designed as well?.
Old 8th January 2008, 04:57 AM   (permalink)
No, it was intended for a single input at any one moment.
Krumlink is offline
Source & Sink Question? shaneshane1 General Electronics Chat 1 22nd November 2007 02:36 AM
Source or Sink? UTMonkey General Electronics Chat 2 3rd November 2007 08:11 PM
Current Source vs Current Sink? dknguyen General Electronics Chat 11 14th September 2006 11:26 PM
not gate (inverter) ic that can source and sink 15mA Thunderchild General Electronics Chat 22 23rd August 2005 05:55 PM
Crazy Resonance Problem cchalmers General Electronics Chat 31 14th February 2005 04:47 PM
