| Being ZIF sockets so expensive locally I used tourned pins as longtime ago, Nigel reccomended for frequent insertions. Just one precaution: have both lines exactly vertical (parallel to each other) and micros' pins straightened accordingly. Thanks for that Nigel!
__________________ Agustín Tomás In theory, there is no difference between theory and practice. In practice, however, there is. | |
| Also referred to as machined pin sockets, I believe, and definately worth the few extra pennies per socket. | |
| As a side issue. I found that when using the larger Dallas ic's, 28/32 pin, with the thick potted body, that the lead out pins are a little shorter than the standard DIP. As a result any vibration caused the ic to lift out of the ic 'leaf' type sockets. The cure was to replace the leaf type ic socket with a turned pin ic socket, this cured the problem 100%.
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ | |
here is a good reason to be convinced that machined sockets are worth the few extra pennies: I got an industrial computer for repair some time ago. The device was operated in industrial environment with moist air. All the IC pins were corroded black, also inside the sockets, as well as the socket pins. Using TTL-logic like in this case, supposedly low pins pull themselves high if there is high transition resistance between the pin and the socket. I cleaned the ICs thoroughly and replaced the sockets by those with machined pins. The device worked properly right again after this measure. One year later I visually checked the computer. All IC pins had turned black again with the exception of the contact area inside the machined pins. The contact between IC pin and socket pin is air tight and secondly the machined pins are made of beryllium-copper alloy with almost no oxidation. Regards Hans | ||
| Stick the micro in a socket and use that socketed IC to insert/remove- never risk the IC's own pins
__________________ blank | |
| Always use chip pullers. Helps save those pins. http://www.mouser.com/Search/Product...QsOR45dw%3d%3d Last edited by speakerguy79; 7th January 2008 at 04:45 AM. | |
I usually just use a flat head screwdriver and slowly pry both ends; once the pins are past a certain point the IC will just slip out.
__________________ -Ian | ||
| We use ones here at work that look like the ones in the Mouser catalog link that I posted. I am not sure if they are identical or not. But I use them all the time and haven't had a problem on anything from 8 to 28 pin DIP's. | |
| Bought mine (a set in fact) and works OK au pair with a nice breadboard some 20+ years old.
| Attention Plz Mr NIGEL | thenewton | Chit-Chat | 16 | 9th March 2007 02:21 AM |
| 7 segment display with less pins | bananasiong | Electronic Projects Design/Ideas/Reviews | 21 | 2nd December 2006 03:21 PM |
| Congrats to Nigel Goodwin - now an Electro Tech moderator! | ElectroMaster | Feedback/Comments | 9 | 18th April 2005 09:15 PM |
| Pins on a DC power jack | dak246 | General Electronics Chat | 4 | 21st October 2004 08:59 AM |
| From Rosy to Nigel Goodwin | Rosy | Micro Controllers | 2 | 8th May 2004 12:00 AM |
