Old 4th January 2008, 07:02 AM   (permalink)
Default LM311 Balance Pins
Does anyone know exactly how the two balancing pins work on the LM311 comparator? All the app note sfrom the all the companies seem to be copy/pasted from the same source and provide sample circuits but they don't ever seem to say what each balance pin actually does and how they interact with each other. (I'm trying to provide hysteresis without linking the inputs and outputs for positive feedback loops.)
dknguyen is offline
Old 4th January 2008, 07:28 AM   (permalink)
Did you see Fig. 1 (on p.11) in the National datasheet? Read the accompanying text.
EDIT: Q5, along with R1, R2, R3, R4, and any external resistance you provide, in the National schematic forms current sources for Q1 and Q2. The Base-emitter voltages of Q1 and Q2 can be (un)balanced by adjusting these currents. That's what the balance circuit does. Positive feedback from the output to pin 5 also unbalances these currents, causing "offset voltage" in Q1 and Q2, which must be overcome by the input signal in order for switching to occur.
Ron
Roff is offline
Old 4th January 2008, 07:32 AM   (permalink)
Yeah I did. BUt I'm trying to minimize the number of components since I don't need offset adjustment and I am unable to separate out what does the offset adjustment and what is required for the hysteresis.
dknguyen is offline
Old 4th January 2008, 07:39 AM   (permalink)
Read my edit, although it probably won't help.
Ron
Roff is offline
Old 4th January 2008, 07:43 AM   (permalink)
I would start out by eliminating the 5k pot and the 3k resistor, then tweaking the 33k until you get the desired hysteresis.
Ron
Roff is offline
Power Supply "Sense" Pins Ambient General Electronics Chat 10 21st October 2008 09:07 AM
7 segment display with less pins bananasiong Electronic Projects Design/Ideas/Reviews 21 2nd December 2006 03:21 PM
ic pins laurent sixtooth General Electronics Chat 3 19th February 2005 02:18 PM
Pins on a DC power jack dak246 General Electronics Chat 4 21st October 2004 08:59 AM
Balance Pots Screech General Electronics Chat 6 30th March 2004 12:00 PM
