Old 3rd January 2008, 11:05 PM   (permalink)
Default Schottky diode as rectifier
hello all,
i was doing some basic tests with a schottky diode, without succes, so finally i've decided to ask for some help, since i'm sure missing something important about the theory.
I have put up a circuitry like in the picture attahced
I would try to rectify the reduced 125 Khz signal. Due to the 125 Khz frequency, i've decide to use a schottky diode (don't know if the choice is appropriate), so i was expecting to see in his cathode a only-positive pulsed half-wave. Instade i continue to see by oscilloscope a complete sinusoidal wave.
if any help,
many thanks, angelo
spectrum is offline
Old 3rd January 2008, 11:24 PM   (permalink)
What kind of diode are you using? Diode capacitance can cause this. If you are using a high-current diode (high capacitance), then you need a low-value resistor as a load. You apparently are using an oscilloscope. The input resistance is much too high.
Ron
Roff is offline
Old 4th January 2008, 03:06 AM   (permalink)
Yes, the input resistance of the scope is very high, like more than 1 Mohm. You need to load the right side of the diode with a resistor to get what you want. Resistor value should be much more than the values of those two on the left, but not nearly as high as 1 Mohm.
RadioRon
RadioRon is offline
Old 4th January 2008, 04:19 AM   (permalink)
If your Schottky diode can survive 38V then it should have the attenuator as its load like this:
audioguru is offline
Old 4th January 2008, 05:00 AM   (permalink)
Schottkys are fast, yes? Silicon-metal diode, no minority carriers to sweep out? Or is my semiconductor physics bad?
speakerguy79 is offline
Old 4th January 2008, 05:26 AM   (permalink)
Big Schottkys have big junctions, and therefore lots of capacitance.
Ron
Roff is offline
Old 4th January 2008, 05:38 AM   (permalink)
Wow, I've never seen a Schottky that did 200V!
Old 4th January 2008, 06:53 AM   (permalink)
Nor I. I kind of need one.
dknguyen is offline
Old 4th January 2008, 10:10 AM   (permalink)
Thanks all,
sorry for incomplete data, the diode i'm using now is 1N5819, but i eventually can buy another one i need in 5 minutes from my home.
Yesterday i've imagine something about it, looking some diagrams here and there, so i've try to load the right part with a 33K resistor, but i can't measure anything anymore at the cathode, 0 level always.
Thanks again,
Angelo
spectrum is offline
Old 4th January 2008, 05:19 PM   (permalink)
Originally Posted by spectrum
Thanks all,
Thanks again,
Angelo
What are the values of your resistors, and why are you doing this?
Ron
Roff is offline
Old 4th January 2008, 05:30 PM   (permalink)
values of my voltage divider are 10M and 2,2M. Actually i'm just wandering how i can see the positive-only signal i was expecting, with negative part cutted by the diode, and then if possible to have a DC from this signal, using a capacitor.
angelo
spectrum is offline
Old 4th January 2008, 05:59 PM   (permalink)
A total of 12.2M is not a load. Try it with 10k in series with 2.2k.
Old 4th January 2008, 06:16 PM   (permalink)
200V... get them upto alot higher
Nothing is impossible.
Styx is offline
Old 5th January 2008, 03:23 AM   (permalink)
FWIW, I experimentally discovered my 1N5822's will actually do 50% more PIV than they're rated for. Failed short though - is that normal?
Old 5th January 2008, 03:59 AM   (permalink)
How about 6kV? Pie in the sky, of course.
Schottky diodes made on these epitaxial diamond films have breakdown voltages >6 kV, twelve times the highest breakdown voltage reported for any diamond diode and higher than any other semiconductor Schottky diode.
Ron
Roff is offline
schottky diode shermaine General Electronics Chat 13 17th September 2007 11:11 AM
difference between a normal diode and a schottky diode jin29_neci General Electronics Chat 18 14th September 2005 07:21 PM
Schottky diode characteristics? Oznog General Electronics Chat 0 12th April 2005 06:11 AM
Here is a list of semiconductor prefixes. TPS Datasheet/Parts Requests 0 21st December 2003 08:24 PM
Identify Semiconductors by prefixes mixos Datasheet/Parts Requests 0 10th December 2003 07:56 PM
