| You simply don't understand the whole concept of "earthing", do you? By placing the electrical circuitry inside a metal box, which is connected to earth, and with one side on the a.c. supply joined to earth (at the sub-station), an electrical failure that results in the metal case becoming 'live' blows the supply fuse - thus saving the user from receiving an electrical shock. Therefore, to ALL test equipment should be earthed at all times in the simple interest of user safety. You don't seem to understand the basics of SMPSUs, either. If I wish to examine the waveform across the filter capacitors in a switch-mode PSU, where these caps. are fed from a bridge rectifier DIRECT from the a.c. mains, I MUST, repeat MUST connect the earth lead of my scope to the -ve of the caps.- otherwise, there is no reference for the 'scope to work to. To do this, a mains isolation transformer is ESSENTIAL between the a.c. supply and the PSU - otherwise there will be a dead short across the bridge. There is no debate to be had on ANY of these aspects: they are simple, provable facts. Only the ignorant and mis-informed would disagree. No more need be said. Period. Hum Bucker. | |
| | (permalink) | ||||
As you're blindly rattling off domestic earthing standards you're obviously far too young to remember the huge controversy over earthed and earth free environments?. I'll fully agree it makes great sense in a domestic environment, particularly when you have washing machines, dishwashers, steam irons - anything that has water anywhere near electricity. But a service environment is a completely different affair!. I might also mention I've been on training courses at huge international electronics companies, and in their training rooms there are no isolation transformers, and all scopes have their earth leads removed. I can't remember the last time I ever used an earthed scope?, at technical college all scopes were unearthed - again, for greater safety. Mind you, at technical college they also had live bare brass 440V three phase terminals on the walls! - that was in the heavy machines lab, which we had a number of lessons in (by complete mistake as it happened). Quote:
| | (permalink) | ||||
However, on a controlled environment like a test bench, it's normally only single phase and you know what you're connecting to it so the above problems don't occur. Quote:
The only time I would agree with disconnecting a safety earth connection is when you're testing something that's got its 0V rail bonded to protective earth (PCs and some audio amplifiers). This is because failing to do so will result in a troublesome ground loop. This isn't dangerous at all as you're still earthing the appliance by connecting it to the scope's earth bonded chassis. Quote:
In the 1960s may be, but not in 2008 and just because you've seen it done before it doesn't mean it's safe.
__________________ I also post at the following sites: http://www.stop-microsoft.org http://www.heated-debates.com Screen name: Aloone_Jonez | |||||
| Maybe I should go to another forum; I did not mean to get something going. My bad. I simply read an article on common reasons these power supplies blow fuses. It described that it's highly typical for the diodes next to the filter cap/s to dead short for no reason. This seems to be true in my case but I want to make sure other components down the line after the diodes were not affected. It was described that it is possible that the filter cap/s could go bad. I am sure that this is typical but I thought I would just mention that there is a capacitor that crosses beside with the fuse. After installing a few fuses as I was trouble shooting I notice this capacitor would finally "pop" so to speak. Blow a little ceramic pc off it's self. I would assume this wouldn’t help as it is probably a result in the dead short. Eric | |
Some times you have to unsolder one end of a component in order to test it.
__________________ Len | ||
| hi, Ref earthing standards.
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 7th July 2008 at 12:23 PM. | |
| | (permalink) | ||||
| hi. As an employer I had to work within the H&S safety guide lines. If an employee/or a third party is killed or injured due the employer/manufacturer not adhering to the H&S standards, it leaves him open to prosecution and compensation claims. If you are shown to be negligent your insurance company is not liable for the compensation claim. Ref the isolation transformers, IIRC any work/test bench must have a distance of 1.5 metres from another work/test bench that is using an isolation transformer.
| Last time we had the factory inspectors round, did they want to see the isolation transformers? NO, did they want to see the low voltage soldering irons? NO, did they want to see the isolated aerial sockets? NO, were they interested in an earth free safe environment? NO. What did they ask? - "DO YOU HAVE ANY TOILETS" (yes we do, this is the 20th/21st century), and "DO YOU HAVE H&S INFORMATION LEAFLETS ON THE AEROSOLS YOU USE" (yes we do, all H&S leaflets, information, and everything we've ever received is chucked in a suitably labelled box file). They went away EXTREMELY happy, we had toilets, and we had instant access to all H&S information, in a nicely labelled box. Personally I thought they were a COMPLETE waste of time, however the senior inspector was a really cute young woman, which made it all worthwhile! | |
| These H&S courtesy visits are always much of a non event, I suspect its a case of getting their batting average upto par!.. Its when things go badly wrong they roll out the big guns, then they will go thru your company with a fine tooth comb. The companies insurers will then also give you the once over. I think most of us cut corners on safety from time to time in order to get the job done, in hindsight thats not a good idea. I would ALWAYS advise that the Statuary regulations regarding safety be followed at all times, especially, if I am advising an inexperienced person. The danger is, many of the OP asking for help have no experience, so in reading some of our bad habits and practices, it could place tham at risk. I have seen you on a number of occasions, caution and warn an OP not to attempt certain repairs/projects. There's a young guy currently asking about 'dc fault finding',, It sounds like a SMPS problem, My advice will be not to attempt the repair.
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 7th January 2008 at 01:17 PM. | |
| since you have 2 of them, you could short the leads on one PSU and see what blows up, then follow down what blew up, and it should be the same problem on your other. Of course if 2 failed, they were probably el cheapos with every party not being worth a crap, so in that case, throw it in the recycle bin and send it back to china! | |
I'm glad you are around to give out such HELPFUL technical advice...
| Len, Yea I have removed each component as I have tested. ------------------------------------------------------ Shorting out the unit is not going to give me the same results as a component that shorts out internally, as far as what does and doesn’t become damaged. Eric | |
Are you able to trace out the relevant part of the circuit? I have a circuit of the SMPS of my daughter's VCR. I could scan it and post here. It won't be identical to your's, but it should give you some idea of what a SMPS looks like.
| | (permalink) | |||
Also, the scope case only needs to have single insulation between from the mains so if it developed a fault then you'd be totally knackered. Quote:
I don't know why the scope manufacturers grow a brain and make double insulated scopes, they'd be so much more usefull and safer too.
| Motor Power Supply questions | ravix | Electronic Projects Design/Ideas/Reviews | 6 | 15th January 2008 10:34 PM |
| Got a new EVBoard How do i supply power to it? | cubdh23 | Micro Controllers | 2 | 3rd August 2007 10:39 AM |
| 24v DC Power Supply (Help & Information Wanted Urgently) | ampthetex | Electronic Projects Design/Ideas/Reviews | 5 | 17th November 2006 01:45 PM |
| need help with power supply parts very info... | rodniepr | General Electronics Chat | 0 | 6th April 2005 04:33 AM |
| Low current power supply from stored current. | McGuinn | Electronic Projects Design/Ideas/Reviews | 12 | 20th January 2004 07:15 AM |
