Old 4th January 2008, 10:07 AM   (permalink)
Originally Posted by RadioRon
Can you google for a schematic? Please try harder to find this yourself.
For example, if you google "envelope detector" and then take the first choice given, you will see a schematic.
i have seen plenty of schematics.Thanks but will i have a result with this cause i use squeare wave 25%duty cycle frequency not ac input.So the capacitor will stay charger when the input is low for the 75% to active my transistor?probably i have to use a big capacitor to achive this.What do you think?
ariakovo is offline
Old 4th January 2008, 10:09 AM   (permalink)
Originally Posted by ericgibbs
You say continuous data, do you mean a simple continuous, unmodulated IR beam.
Post a sketch of the project so that we can see what you are trying to do.
Yes you have right i mean unmodulated IR beam.I put only a frequency in the emmiter and i am trying to detect this frequency from the receiver.
ariakovo is offline
Old 4th January 2008, 10:39 AM   (permalink)
In that case use a 567 tone decoder ic after the IR detector.
Please post a simple diagram.
http://www.njsas.org/projects/bat_de...pulel_sch.html
I know this is for ultrasound but will give you an idea...
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is online now
Old 4th January 2008, 11:49 AM   (permalink)
Hi ariakovo,
I understand how datasheets can be confusing, because other applications than the one you want may also be presented. In the case of the 567, go to its page 8.
You will see a circuit called AC test circuit and application information on the right side that gives the formula for calculating the frequency you need. In this case, it is:
1/(1.1*R1*C1)
I have attached a part of a schematic from a circuit I built with actual values. I don't recall at the moment what its frequency was. On that circuit, the components to adjust the frequency are labeled C4, R7, and R8. That is, the RC filter attached to pins CT and RT. YOu will need to calculate appropriate values for the frequency you decide to use. Good luck. John
jpanhalt is offline
Old 4th January 2008, 12:25 PM   (permalink)
Ok i am sending you the diagram.Maybe i will make a high pass filter because i don't have a lot of sapce in there.I am waitin the components the next week for testing.Also the filter invert the output.If i solve this problem we will talk about this later maybe i will find a solution but i want this first.Thanks for you time
ariakovo is offline
Old 4th January 2008, 12:34 PM   (permalink)
Originally Posted by jpanhalt
Hi ariakovo,
1/(1.1*R1*C1)
Thanks for the tips.You said that there is a RC filter.Can i use the lm567 like a filter and like a demodulator?For example if i put one other frequency how will respond.If i can't it's ok.I understant how to calculate the frequency.Thanks
ariakovo is offline
Old 4th January 2008, 12:55 PM   (permalink)
It will respond only to the frequency to which it is tuned (don't forget it has a finite bandwidth). A sufficiently different frequency will not cause a change in its output state. In fact, its name "tone decoder" described that function. A series of 567s tuned to the different telephone tone frequencies could tell you which keys had been pressed. John
jpanhalt is offline
Old 4th January 2008, 03:05 PM   (permalink)
Thanks a lot!!
ariakovo is offline
Old 4th January 2008, 03:28 PM   (permalink)
The envelope detector is a good circuit to start with. It will detect the presence or absence of any signal over a wide bandwidth. To be more selective there needs to be something that responds to frequency. Googling "phase locked loop" will also result in numerous hits. Check out the number two hit
http://www.uoguelph.ca/~antoon/gadgets/pll/pll.html
Papabravo is offline
Variable capacitor circuits walters General Electronics Chat 83 11th March 2008 03:59 PM
PLL basics notwist General Electronics Chat 8 3rd November 2007 01:25 PM
pic16f84a led frequency danielec Micro Controllers 6 10th November 2006 12:52 AM
Optimal quench frequency mstechca General Electronics Chat 1 1st July 2005 06:13 AM
PIC12F675 Design Suggestions - Frequency to Frequency dsfii Micro Controllers 1 23rd May 2004 06:41 PM
