Old 31st December 2007, 08:20 AM   (permalink)
Default Gate of triac
I am designing a dimmer with a triac. It's mentioned in the teriac datasheet that the max gate current is 35mA. I have designed the attached circuit but I don't know how to calculate the gate current. The circuit works properly but I'm not sure it's safe while triggering or not.
Please check the circuit and let me know your opinions.
Fahime is offline
Old 31st December 2007, 09:04 PM   (permalink)
What does the 22nF capacitor do and what does the 0.1uF capacitor do? (I'm not good at figuring out circuits like this). I'm not sure which one is sending the current pulse to turn on the triac. But I think you can calculte the current pulse by looking at the voltage of the capacitor just before it discharges and then use I = V/R to estimate the peak current pulse. It doesn't seem to me it would be too high, especially for the 15K resistor and the 0.1uF capacitor. I'm not sure about the 22ohm resistor and the 22nF capacitor, but I don't think it will cause a problem either. (no real reason though).
dknguyen is offline
Old 31st December 2007, 10:13 PM   (permalink)
Your peak gate current will occur when the diac triggers; basically the diac's "delta-V" voltage divided by 22 ohms. The duration of this pulse will be approximately 22*22*10e-9, which works out to about half of a microsecond.
We could be more specific if you include part numbers for the diac and triac.
mneary is offline
Old 31st December 2007, 11:14 PM   (permalink)
Is this Fig.Test Circuit...?
But A1-A2 pins in Terminal short circuit.And Test Circuit (!) not to work.
Hayrettin Demir is offline
Old 31st December 2007, 11:59 PM   (permalink)
HEhe, yeah. Good call. I would assume the OP would stick a light bulb in series with the triac? (hopefully anyways!)
dknguyen is offline
Old 1st January 2008, 09:24 AM   (permalink)
Originally Posted by dknguyen
What does the 22nF capacitor do and what does the 0.1uF capacitor do? .
They're just for changing the trigger angle of the gate. they shift the input voltage of gate to a better control of lightening.
Originally Posted by mneary
Your peak gate current will occur when the diac triggers; basically the diac's "delta-V" voltage divided by 22 ohms. We could be more specific if you include part numbers for the diac and triac.
The diac is DB3 and the teriac is BT138. the diac conducts in 33v. as I calculate the current of conducting the diac is 33/22=1.5A and it's more than 35mA.
But in the datasheet of teriac u see 2 factors: 1. the max gate current=2A
2. the max gate trigger current =25-50mA
when the circuit works it seems safe but i'm not sure that 1.5 A is in the moment of triggering or not. Pleasedescribe it for me.
Fahime is offline
Triac light bulb flasher ElectroMaster Electronic Projects 17 30th July 2008 04:20 PM
Triac problem. robyelectron Electronic Projects Design/Ideas/Reviews 0 2nd August 2005 12:15 PM
555 Triac MAC15SM pop General Electronics Chat 4 6th March 2005 02:06 PM
Triac Gate Pulses pop General Electronics Chat 0 15th February 2005 11:54 PM
Cross-Coupled Nor Gate Cell and Cross-Coupled Nand Gate Cell shermaine General Electronics Chat 5 24th March 2004 11:49 PM
