I could not find a model number, will look again, but I have a Sanyo 27" flat glass CRT type TV.
For years I could see the re-trace lines a little in the picture if I got close to it. Now, I think the issue is coming to the front. I know TVs are cheap but if I can fit it, I like this old TV.
I think it is maybe 5-7 years old. Has 2 s-video and 2 RCA sets of inputs.
What it is doing, it will be fine then it will go bright white full screen for a bit and then flip back to normal. Hoping it is a simple cap somewhere and someone like Nigel has seen this before
Any ideas outside of a new TV. It is ashame the schematics will probably cost 1/2 of what a used TV will cost.
solder all components on crt board first, before any test/adjust to be done. .You may get an "Unbalance White" (white as white Paper on Screen). BIG!!!! TROUBLE on adjusting RGB Bias. Specially on moving object/changing color on the screen.
