| Wow your motor, idea sounds expensive, power hungry and unreliable, I don't know how you got all three in one! Filter any waveform with a 50% duty cycle enough and you'll get a sinewave. Build a 7555 timer circuit with 50% duty cycle, add a non-inverting buffer to the capacitor, stick a picky enough filter on the end and you'll have a near as damn it perfect sinewave.
| A switched-capacitor Butterworth lowpass filter IC does wonders to remove harmonics. A square-wave can be filtered with an 8th-order IC and the results are low distortion sine-wave. My very low distortion sine-wave generator uses a CD4018 to make a stepped sine-wave with 10 steps (10 times over-sampled) then is filtered by an 8th-order Butterworth filter IC. The distortion is 0.01%.
| is this gonna be some strictly controlled output? you could keep it simple, LC tank. dang yall love things complicated more than they have to be. | |
| You could if you played it out of a huge sub woofer but it'd probably make you feel ill rather than lovely.
__________________ --- The days of the digital watch are numbered. --- | ||
It seems like alot of phaser circuits use JFETs. how do they get around the distortion? | ||
| Distortion isn't a problem with a phaser, it's entire reason for being there is to distort the signal anyway. Why don't you try googling for phaser circuits, and see how thousands of others have overcome the problems? On the other hand, although I'm presuming you're wanting to build one for the pleasure of it?, why not just buy one? http://www.bluearan.co.uk/menu/index...e=manufacturer Nice box, at less than the parts are goint to cost you!. | |
| ha, i already have one. im having lots of fun with this. | |
| | (permalink) | ||
BUT, he needs the amplitude to stay constant regardless of frequency, from 0.2 Hz to 1.75 Hz if I recall correctly. So, with that approach, either the filter's corner frequency would need to be moved up, to be able to even try to keep the amplitude constant vs frequency, and the filter would need to have many (many) more stages, and it still wouldn't have constant amplitude vs frequency, OR, he'd need to use a smaller bank of adaptive filters, with a variable corner frequency, and some way to control it, and some way to know when and how to control it. The motorized oscillator idea had a lot of potential problems. But at least it did hold a constant amplitude versus frequency. Last edited by gootee; 31st December 2007 at 10:01 AM. | |||
