I have a IRED that have the following characteristics and i have a phototransistor that also have the following characteristics. I want to know how to calculate the distance between them from their characteristics.The manufacture is Perkin Elmer optoelectronics. Thanks. | |
What makes you think you can?.
What i have to do to calculate the distance.I want more characteristics?Or it isn't possible.Any idead?
I don't think it's possible, certainly not repeatably, or to any degree of accuracy - try it and see, I don't see as any calculations wil help you.
I want to achive 6 or 8 m distace but with only a ired and a phototransistor.Maybe and an amplifier for the phototransistor nothing else.Can i achive this distance with these components
| | #6 |
You certainly require an amplifier, and considerable gain! - with LED and photo-transistor alone you're probably talking millimetres not metres. But what EXACTLY are you trying to do?. | |
| | #7 |
I am trying to do ir photo detectors.Photo sensors that detects objects if the beam cuts.For various applications like doors(if anyone pass the door then open the lights) etc.
| | #8 |
For the large distances you're talking about, it's probably easiest to use IR receiver IC's, and modulate the transmitter at 38KHz. You also need to provide some sort of coding as well - the receiver won't work with just a carrier. Probably the easiest way is to use a small PIC at each end?.
| | #9 |
I think if you want to measure the distance accurately, you should use the ultrasound transmitter and reciever.
__________________ Khizer Naeem Mughal IIUI | |
| | #10 |
I don't have space and the cost of a PIC is to high for this application. I have use ir receivers modules but i had the problem that you say. I had to send some data so. I beleve that an ired , a phototransistor and an applifier.Or and ired that send a frequency in 30KHz a phototransistor a band pass filter and an applifier.What do oyu think?
| | #11 | |
However, if you would rather use seperate amplifiers and filters it's a perfectly valid old method. | ||
| | #12 |
I want only to know what is the distance that i can achilve between the emitter and the receiver. The distance that i can detect an object between. I don't want to mesure the distance with these components.Thanks
| | #13 |
I understund. Thanks very mutch
| calculate, distance, pair |
| Distance measurement project | bigfarmerdave | Electronic Projects Design/Ideas/Reviews | 13 | 14th December 2007 07:42 PM |
| Using Oscilloscopes | mechie | Electronic Theory | 9 | 29th November 2007 10:49 PM |
| resolution of distance measurements | williB | General Electronics Chat | 10 | 22nd March 2005 08:08 PM |
| min. distance in ultrasonic distance meter | Maryam | Micro Controllers | 2 | 9th August 2004 11:18 AM |
| some divice can calculate the distance that it move | fatal_error | Electronic Projects Design/Ideas/Reviews | 2 | 5th October 2003 12:25 AM |
