Old 24th December 2007, 07:08 AM   (permalink)
Default ICL7106 and LCD problem
I have been doing a project using a LCD and the IC 7106. The problem I have is that additional decimal points are showed on the LCD screen, but I didn't connect the respective pins ! ?_? I only connected the first right decimal point.
Maybe some experienced users have had similar problem , that's the reason I posted here this problem.
Circuit attached
any thoughts?
mabauti is offline   Reply With Quote
Old 24th December 2007, 08:03 AM   (permalink)
You have to connect the unused decimal point pins to the LCD backplane [BP] pin to switch them OFF.
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is online now   Reply With Quote
Old 25th December 2007, 12:48 AM   (permalink)
COM or COM1?
should I connect both COM & COM1?
Old 25th December 2007, 08:33 AM   (permalink)
Originally Posted by mabauti
COM or COM1?
Look at the 7106 pins, see the BP pin, this is the Backplane osc output.OK.
Eric
PIC tutorials:
Old 25th December 2007, 09:32 PM   (permalink)
excuse me : should I connect both COM & COM1?
and , just a last question : the LCD reading drifts randomly , e.g. : from 25.8 to 27.4 then 26.9 then 33.7 then 25.4 , etc.
any comments about this?
Old 26th December 2007, 09:34 AM   (permalink)
I cannot find a datasheet for the LCD??
Do the readings drift when the input probes are shorted together?
Also, how are you powering the 7109?
EDIT:
The connections for generic LCD are shown, its says link commons..
Eric
PIC tutorials:
Old 26th December 2007, 07:13 PM   (permalink)
I shorted D1 first, then IN-HI & IN-LO and both drift
as indicated in the schematic, using a 9V battery. I tried with an AC adapter too (same result)
Old 27th December 2007, 08:23 AM   (permalink)
It looks as though you are using the diode as a temperature measuring sensor???
Where did you get the circuit design from?
Also I dont see any decoupling on your circuit diagram, I appreciate you are using a 9V PP3 battery, but these batteries do have a 'high-ish' internal resistance.
The 7106 will generate some electrical noise on the power rails and you have the sensor diode and Vref/offset connected to that rail.
Connect a 47uF and a 0.1uF capacitor across the power rails.
Have you measured the 9V battery voltage when the circuit is connected.?
Eric
PIC tutorials:
Old 27th December 2007, 11:30 PM   (permalink)
It was only for schematic purposes, actually I'm using a NPN BJT
Electronics Now , March '95
I'm using both : rechargeable and alkaline, even an AC-DC adapter
Done, same result =[
It has a stable reading
btw: the only difference between that design and that of intersil datasheet is the 1Mohm resistor in the zero adjust pot
Old 29th December 2007, 09:30 PM   (permalink)
so what's your conclusion ericgibbs? :
Does the schematic not work (it is wrong)?
should I make the PCB again?
Old 29th December 2007, 10:28 PM   (permalink)
Hi Mabauti,
Try changing the integrating capacitor, the same value but a different
type of capacitor. See if you can find a polypropylene type.
See also page 10 of the datasheet.
on1aag.
on1aag is online now   Reply With Quote
Old 29th December 2007, 11:46 PM   (permalink)
How far away is the temperature sensing transistor from the rest of the circuit? Are you using a shielded cable as depicted in the diagram with the shield connected to pin 32 of the 7106?
kchriste is offline   Reply With Quote
Old 23rd January 2008, 03:51 AM   (permalink)
Default Re:
It is working now! o_Ô
I did what on1aag1 said, the circuit became more stable, however it still had drifting (pretty much less though). I blame batteries w/o enough charge (I'm using the same batteries I started with)
~10 centimeters
No at any time.
A new question rises about this kind of IC, from the following schematic
http://www.interq.or.jp/japan/se-inoue/gif/ckt26_11.gif
Question : Will the LCD be burnt because of connecting directly the TEST pin to the DP1?
Old 15th April 2008, 04:23 AM   (permalink)
hi mabauti,
PLZ send me c code of your time display project.......
i want to introduce this future in my college project........
plz help me............
hm:
sachin.kolkar is offline   Reply With Quote
Old 15th April 2008, 04:28 AM   (permalink)
hi Kchriste,
Plz send me some C example code for real time clock....
I m using PIC uC .........
PLZ help me boss......
hm:
