Hopefully I managed to get the circuit diagram up... I am troubleshooting one of these amps and there are a few things I don't understand (I had trouble liek this last year). My circuit right now contains all passive components and only T1. I connected a sine input of about 1 V and I get a distorted waveform (clipped positive wave) on the collector of T1. The base of T1 shows about 40V dc and the input voltage is 70V. Why is there any clipping? Uwe | |
You can't test the amp without enough parts to make it work, you can't just fit T1, it won't work at all.
Well Nigel, people test circuits in stages all the time, so of course it can be done. But maybe you are right that I do not have enough parts to make the input stage around T1 work, but this is why I posted my question, since the circuit does give me trouble I need to test it in stages. So I do not want to let your comment discourage me from doing so, I will rather look for a solution which allows me to test just this one stage with it's bias setting components. And if you know how to do this then I would welcome your comment(s). Uwe | |
To test T1's bias, look where its emitter voltage comes from: the output stage. If you set the right side of R8 to Vcc/2, T1 should behave. If you then install T2 and T3 at the same time (sorry, they are highly interdependent), then you might see how they work. T6 and T7 then might be checked by replacing their emitter resistors with 100 ohms (50 watts each). Finally, T4 and T5, which are overload detect, will be difficult to test. Last edited by mneary; 20th December 2007 at 02:00 AM. | |
| | #5 | |
| | #6 |
T1 has no voltage gain so adjusting the P1 trimmer pot won't do anything. The base of T2 has 3 diodes biasing it so the small change in current from T1 through R6 won't change T2 much. I think R6 and the 3 diodes should be removed.
| | #7 | |
Follow Mneary's advice and set the right side of R8 to Vcc/2 if you want to simulate a partial circuit.
__________________ Inside every little problem, is a big problem trying to get out. Last edited by kchriste; 20th December 2007 at 05:45 AM. | ||
| | #8 |
I think it would have been better had you not started another thread on the same topic.
| | #9 | ||
What you could do though is simplify it a little, T4/T5 and associated components are for over current protection, you can remove and ignore those for testing. You could also short out T3 (collector to emitter), this sets the bias to zero, so stops thermal runaway - but gives high distortion at low levels. Once the amp is tested and working you can remove the short across T3, ensure the bias is set to minimum, and then gradually increase it while you monitor the current. Last edited by Nigel Goodwin; 20th December 2007 at 11:14 AM. | |||
| | #10 |
Well first of all I do thank you all for the attempts to help. I do have half knowledge or less when it comes to electronics. I can follow the explanations why some things work the way they do but if then they do not work properly it requires an altogether different level of knowledge to know where to tweak it. The amplifier I mentioned here simply blew the fuse and the two output transistors when I switched it on. I have 5 working ones, this one does not work. Obviously I am reluctant to simply put two new transistors in and switch it on again. I am trying to figure out why it did this and the safest way would be two build it in stages and 'inch' towards the complete amp. Nigel strongly argues that that is not possible, others are less strict and suggest testing stages here and there. As I said I am in no position to argue either case, all I hope is to learn something here and in the process -hopefully- also finish this amplifier without having to buy output transistors by the caseload. And now I wonder which advice I should follow, test the whole thing as one or try some partial solutions?!?! Uwe | |
| | #11 |
Since the fuse and both T6 & T7 blew on power up, the most likely problem is that the wiper of P2 is open or P2 is set for maximum resistance. The next likely thing would be that T3 is defective (open).
__________________ Inside every little problem, is a big problem trying to get out. | |
| | #12 | |
Completely changing the circuit to try and check each section separately doesn't achieve anything, what you're checking needs modifying so much it bears no resemblance to the real circuit, and when you restore and connect them all it's the interaction that makes it go BOOM!!!. | ||
| bias, question |
| Capacitor Charge/Discharge question | ThermalRunaway | General Electronics Chat | 25 | 12th August 2008 05:48 PM |
| Soundcard input bias question | Torben | Electronic Projects Design/Ideas/Reviews | 7 | 24th November 2007 06:54 PM |
| Open Book Test Question | raywl | General Electronics Chat | 3 | 5th November 2006 07:41 PM |
| Data Logging question with high speed!!!! | cubdh23 | General Electronics Chat | 4 | 16th August 2004 07:33 PM |
| PBX question | waqar | Electronic Projects Design/Ideas/Reviews | 0 | 30th March 2003 07:21 PM |
