Old 16th December 2007, 01:20 AM   #1
Default 0.693??? RC Time constant
Hi
I know that to find R in a RC Time constant is to do the following
eg: 2(seconds) / 0.000470(farads) / 0.693 = 6140ohms
what does 0.693 represent, i thought that it might have been 0.7V?
shaneshane1 is offline
Old 16th December 2007, 01:47 AM   #2
I think it indirectly comes from the constant e:
http://en.wikipedia.org/wiki/E_(mathematical_constant)
Maybe you meant 0.632 which is the point in the RC curve where the voltage equals 63.2% and T=RC?
http://ourworld.compuserve.com/homep..._Bowden/rc.htm
kchriste is offline
Old 16th December 2007, 01:59 AM   #3
The way the resistor-capacitor charging equation works out, if you set the time duration to be equal to R*C (the RC time constant which also appears in the equation) then the capacitor will have charged to 63% of the full voltage, or discharge down to 100%-63% = 37% of the full voltage.
The 0.693 number used for 555 timer calculations comes from how the voltage charges back and forth between 1/3V and 2/3V, while the RC time constant is for charging and discharging between 0V and +V.
...I think. I've never actually sat down and did the calculations. THat's just my reasoning. I'd like to know too actually.
dknguyen is offline
Old 16th December 2007, 02:01 AM   #4
If you want to find the time constant, you don't need the 0.693
The time constant is just RC
The time constant is the total change divided by the initial rate of change.
For example, 470 µF and 10 khm: resistor, time constant is 4.7 s.
If the capacitor is charged to 5 V, the current is 5 / 10000 = 0.5 mA
0.5 mA causes the capacitor to change at 0.0005 / 0.00047 = 1.06 V / second.
Time constant is 5 / 1.06 = 4.7 s, and it doesn't matter what starting voltage you chose.
(Time constants apply to all sorts of things, not just electricity)
Because the voltage falls, the current falls, so the rate of change of voltage also falls. It's called exponential decay.
The formula is V = Vstart * e^(-t/RC)
where V is the voltage on the capacitor
Vstart it what it starts at
e is the mathematical constant = 2.717......
t is the time in seconds
R is the resitance
C is the capacitance
The way that time constants are often measure or used is with "half-lives", or the time to get to half the start value.
If the time to get to half the start value is Th, then:-
0.5 = e^(-Th/RC)
This gives Th/RC = 0.693 and that is where 0.693 comes from.
Diver300 is offline
Old 16th December 2007, 02:14 AM   #5
0.693 is used to calculate how long the capacitor charges to 67% of the supply voltage then discharges to 33% of the supply voltage in a 555 astable oscillator circuit.
audioguru is offline
Old 3rd May 2009, 08:31 PM   #6
Default The Secret
hi y'all! i came here from google and i will reveal the secret! i also fought a lot to find out where it came from, i found it and i forgot it... but today i found it again! prepare yourself:
it's the natural logarithm of two!
don't believe me?
Multivibrator - Wikipedia, the free encyclopedia
from windows' calculator: ≈ 0,69314718055994530941723212145818
i hope i made y'all happy!
GuiRitter is offline
constant, time
converting time into useful format justDIY Micro Controllers 3 4th October 2005 09:19 AM
sensor activated time measurement rajravi Electronic Projects Design/Ideas/Reviews 1 29th January 2004 02:01 AM
Time Constant 2 herbymcduff General Electronics Chat 2 6th December 2002 06:12 PM
Time Constant, Capacitors herbymcduff General Electronics Chat 1 5th December 2002 11:48 PM
