electret mic preamp questions
3v0
Coop Build Coordinator
Forum Supporter
Just finished building an electret microphone from this which uses a TL072. I subed a 5pf for the 2pf cap and added resistors to the unused half of the opAmp. I have to wait till the AM to buy a 1/8 plug so I can try it with the computer. It does drive a headphone, sounds clean. Hope it stays that way when I attach it to the computer. :D
I will be powering the circuit using a 9V battery. A 10K audio taper controls the output level. I would like to replace it with two fixed resistors. Will the output level be fairly flat/steady over the life of the battery? Or do I need to adjust the output level as the battery ages?
I know I can increase the input level on the sound card if the output drops but at some point I think that will result in hiss/noise.
[ just switched to opera and do not have a spell checker working yet...]
The gain is set by the feedback resistors, and is independent of the supply voltage, until it drops below a useable level - when you will probably get high distortion.
will 3130 or 3140 will reduce battery consumption?
This is my first venture into building anything audio. I used parts I had on hand.
I will order a LM833 and mabye a NE5532 to see how it works. Maybe get some more suitable caps too.
Right now I just want to do some voice recording with a clean background. Latter I will be doing some DSP stuff.
The TL072 and LM833 are shown on their datasheets with a supply voltage as low as 10V. The TL072 has a minimum supply of 7V which is more than a weak 9V battery can supply.
The NE5532 has a minimum supply voltage of 6V which is a dead 9V battery.
The LM4562 dual opamp has a distortion of only 0.00003%, very low noise and a minimum supply voltage of 5V. But its supply current is typically 10mA.
Thanks everyone. Sort of fun to do something a bit different.
Nigel Goodwin said:
Put a socket in and try using different IC's, personally I find it's usually impossible to hear any difference.
Did a little PCB with and socketed the opAmp. I tried to get the gnd plane between most traces.
Edit: added schematic, mostly the same as the original.
Audioguru: The mike element I am using came in a grab bag from RadioShack that I picked up 10 or 20 years ago. Not sure that it would pay to toss a high end opAmp at it. I may look for a better mic if I am unhappy with this one.
You use only one opamp but are using a TL072 dual opamp.
Why not use a TL071 single opamp?
3v0 said:
............... I have to wait till the AM to buy a 1/8 plug so I can try it with the computer. It does drive a headphone, sounds clean. Hope it stays that way when I attach it to the computer. :D
[/IMG]
If you ara using the MIC input of your computer´s sound card, there is usually a DC supply available in the "ring" (middle) contact of the plug.
You may try to use it and eliminate the battery (and its aging problems:D )
An electret mic has a supply current of only 0.5mA. The power from the input of a sound card supplies it which is not enough to power a TL072 preamp circuit.
The output level from the opamp will not decrease as its battery voltage drops, the distortion rises instead. It will have crossover distortion then clipping distortion.
It is working with a 9V battery but the TL072 does not have as much gain as I would like. If both the PC and preamp are set at max it is just enough to make it work fairly well. Might be nice to have some headroom.
The little mic/preamp background noise was very low when I checked it with a headset. When I feed it into the sound card it was noisy. It was picking up noise from a nearby flash drive. :D
Do you screw up the supply from the sound card if you insert a mic with a mono plug?
The TL072 is loosing favor with me. I will get a NE5532 next time I order. To get the LM4562 I have to order from digikey which I only do infrequently.
mvs sarma:
The 3130 and 3140 will not work with the current PCB. Not that it is a big deal to make a new one but I would like to see if it will work as if first. Thanks for the suggestion.
The voltage gain of the preamp is the ratio of R4/R6 plus 1. Its gain of 23 is very low for a mic preamp. Remove your 5pf capacitor and increase R4 to 150k for a gain of 101. 330k gives a gain of 221. 1M gives a gain of 668. You can have as much gain as you want.
Computers are designed by logic experts. They don't know about audio circuits.
I fed my electret mic directly to the mic input of my Compaq 486 pc and it was excellent. The sound circuit was part of the motherboard.
A microphone input has a very low current for an electret microphone. The input will overload if it is fed the output of your mic preamp. You should feed your mic preamp to a line input of your sound card.
I have heard that the very old CA3130 and CD3140 are extremely noisy and are not suitable as a mic preamp.
You may find that there's a lot of noise on the mic input of your sound card. You'll have better noise results if you design your preamp with about 30 db more gain and use a line input.
I also recommend that you look around for transistor microphone preamps. You can get a a lot better noise and frequency response with about 4 transistors.
Great it sounds like I can get it to work better without ordering a new opamp.
I will change R4 to get more gain and use the line inputs.
Then I will start looking at transistor designs.
What would you recomend for the cable between the mic preamp and preamp line input?
It is nice to work on non computer stuff once in a while.
Thanks for the advice to both audioguru and mneary.
To avoid noise pickup you need shielded audio cable. I had a roll and when it ran out I used the cables that come with audio equipment that had RCA plugs on each end.
That is exactly what I wanted to hear. :)
Along that line, is there any point in sheilding the preamp.
I have a nice little plastic case I would like to use. Some people have put them in metal boxes. I am hoping that the ground plane on the PCB is enough.
The wiring of the circuit will pickup stong nearby interference. All my mic preamps are in a metal box.
