Old 9th December 2007, 06:54 PM   (permalink)
Post Transformerless power supply
I am an engineering student and i am curious to know about circuit designing. Recently i have searched about transformerless power supply to step down to 9 to 12 volts but i am unsatisfied with the results. Please help me what are the elements to use and what is the maximum output current we get. Please provide me full details by describing the advantages and disadvantages of this circuit.
satish.kumar1 is offline
Old 9th December 2007, 07:54 PM   (permalink)
This App note from Microchip should answer technical specifics:
http://ww1.microchip.com/downloads/e...tes/00954A.pdf
(I noticed some errors in the index in the PDF document: It refers to "Figure 2: Vout at Startup with 10KW Load". This should be "10KOhm Load". The error is repeated in the index for Figures 2,3,4,6,7,and 8. The actual document Figures are correct.)
These power supplies are generally only used for low currents (ie <50mA).
The biggest disadvantage is "safety", because of the direction connection of the output, and whatever circuit you are powering, directly to the power mains. I have used these, but it is critical that no part of the electrical circuit be accessable to the user. If you have never designed or worked with mains-voltage circuits, I would strongly recommend against these.
Ken
KMoffett is online now
Old 9th December 2007, 09:41 PM   (permalink)
The advantage is low cost and small size. Disadvantages include low current and no isolation from mains.
Gordz is offline
Old 9th December 2007, 09:58 PM   (permalink)
your question is not clear.
1. is it that you want to convert main voltage to a DC between 9 to 12V?
2. or is it a DC to Dc converter not directly linked to mains.
If it is Mains derived, i would suggest that it is risky and even if you are using it, later on you are likely to forget that it is not isolated and likely to get shocked , if not electrocuted???
If some one else is the user the risk is STILL MORE as he would never know?
Let us not get the habit of designing non-isolated circuits.
After all an SMPS with Ferrite transformer will be small and cute for your needs. I strongly suggest this method.
Regards,
Sarma.
mvs sarma is offline
Old 9th December 2007, 11:04 PM   (permalink)
Just for argument sake, couldn't one say that a standard PC SMPS is a "non-isolated" power supply. There are inductor/caps/switching devices, but not true isolation from meaning of the word as one gets with a ppower supply mains input transformer.
Lefty
Measurement changes behavior
Leftyretro is offline
Old 9th December 2007, 11:18 PM   (permalink)
No, s PC power supply is isolated.
Screen name: Aloone_Jonez
Hero999 is online now
Old 10th December 2007, 01:37 AM   (permalink)
In the past it was hard to find small, cheap(!) transformers for low voltage, low current supplies. Disemboweling wall-warts was a hobby option. I've since found transformers the are at a reasonable cost, and don't take any more foot-print space than the large'ish capacitors in the transformerless supplies. Again, unless I really have control of the end use, I'd stay away from the "transformerless mains power supplies".
Ken
Old 10th December 2007, 02:26 AM   (permalink)
Except that you have not taken into account of small modern powers supplies for all the electronic gadgets. They are required to work correctly from 90V~ 260V AC, without any user intervention.
That said, a transformerless power supply is very rare except on products with totally enclosed design because of its associated danger. A switching power supply is not considered as a "tranformerless" design.
L.Chung
eblc1388 is offline
Old 11th December 2007, 01:50 PM   (permalink)
Exactly, most SMPS for small gadgets such as mobile phone chargers are small and efficient and very usefull for hobby projects. Leftyretro is incorrect in stating such PSU are not isolated as the feed back is optocoupled and the transformer is probably better isolated in terms of insulation than a 'normal' mains transformer. Transformerless power supplies are well suited for applications involving mains control such as dimmers etc.
Gordz is offline
Old 11th December 2007, 04:40 PM   (permalink)
Lefty
I agree with the above opinion BUT with changed comments from my side.
Even the ferrite Transformer is an isolation,
How ever the galvanic coupling capacitor shown between the output common and the -ve of the rectified energy of public mains (230/110 as the case may be ) will be the reason for my comment. we observe it in many such power supplies including the "light weight Cell Chargers". an accidental touch on the cellphone while its battery is getting charged,will give a minute shck even if we are well insulated.
Probably bodies of most electrical appliances are expected to be grounded before they are fit for use. hence we don't feel the shock.
Thus I agree to some extent that most SMPSs can not be called isolated.
Regards,
Sarma.
Old 11th December 2007, 05:31 PM   (permalink)
I don't! - at all
It's isolated in exactly the same way as a conventional mains transformer, with a transformer providing isolation between primary and secondary. The components connecting across the isolation barrier (where fitted) are there for safety reasons, and are also present in units with conventional transformers for exactly the same reasons.
It all depends if the appliance is a Class I or Class II device, SMPS or conventional transformer makes no difference.
You can have SMPS's which aren't isolated, but you can also have conventional ones that aren't either.
Nigel Goodwin is online now
Old 11th December 2007, 07:32 PM   (permalink)
Originally Posted by Nigel Goodwin
I don't! - at all
I am quoting the galvanic capacitor as a reason for my opinion. i do remember the non-isolated SMPS designs like few designs used by PowerIntegtation Inc, (www.powerint.com)
Regards,
Sarma.
Old 11th December 2007, 08:12 PM   (permalink)
But that doesn't affect the isolation at all, along with the resistor in parallel it's there to prevent static build-up on the metal parts of a Class II device - a Class II device with a normal transformer often uses the same technique. A Class I device, such as a cmputer, has all external metal earthed anyway, so you can't get a shock from it.
Old 11th December 2007, 08:17 PM   (permalink)
But that doesn't affect the isolation at all, along with the resistor in parallel it's there to prevent static build-up on the metal parts of a Class II device - a Class II device with a normal transformer often uses the same technique. A Class I device, such as a computer, has all external metal earthed anyway, so you can't get a shock from it.
I had mentioned that aspect, and an extract is here
"Probably bodies of most electrical appliances are expected to be grounded before they are fit for use. hence we don't feel the shock."
Regards,
Sarma.
Old 15th December 2007, 12:12 PM   (permalink)
If there is double insulation between the primary and secondary side of a power supply (e.g. wall wart) then the secondary doesn't need to be earthed and it's considered to be a class 2 device.
If there is only single insulation between the primary and secondary side of a power supply (e.g, computer power supply) then the secondary needs to be earthed and it's considered to be a class 1 device.
Now there are power supplies that have metal frames which need to be earthed and are considered to be class 1 devices but the secondary side isn't earthed (e.g. bench top power supply); this is only the case when the secondary has double insulation from the primary side.
Linear Unregulated Power Supply jbchrist Electronic Projects Design/Ideas/Reviews 19 16th February 2007 11:10 AM
24v DC Power Supply (Help & Information Wanted Urgently) ampthetex Electronic Projects Design/Ideas/Reviews 5 17th November 2006 01:45 PM
need help with power supply parts very info... rodniepr General Electronics Chat 0 6th April 2005 04:33 AM
PC Power Supply Problems brentonw2004 Electronic Projects Design/Ideas/Reviews 3 29th March 2005 12:01 PM
Transformerless 5V power supply Patchouli Micro Controllers 8 21st April 2004 11:10 AM
