+ Reply to Thread
Results 1 to 6 of 6
Thread: DC Circuit - Parallel Capacitor and Resistor
  1. #1
    Shelton Newbie
    Join Date
    May 2007
    Location
    Brisbane, Australia
    Posts
    12
    Default DC Circuit - Parallel Capacitor and Resistor
    Hi All
    Can someone tell me what is the purpose of the 10n cap in parallel with the 1k resistor which is on the base of the transistor in this circuit ?
    Thanks in advance.
    Shelton.
  2. #2
    ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent
    Join Date
    Jan 2007
    Location
    Hampshire. England.
    Posts
    10,836
    Blog Entries
    13
    Quote Originally Posted by Shelton
    Hi All
    Thanks in advance.
    Shelton.
    When the npn is hard ON, the top of the cap/base charges to a +V potential wrt 0V.
    As the npn is switched OFF the charge/voltage across the cap is reversed wrt to the pnp base so the pnp switches OFF faster.
    The cap speeds up the switch ON/OFF of the pnp.
    Do you follow?
    Link to my Articles: http://www.electro-tech-online.com/a...icgibbs-55450/
  3. #3
    Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent
    Join Date
    May 2003
    Location
    Idaho, USA
    Posts
    6,723
    Quote Originally Posted by ericgibbs
    Eric, this isn't true, because there is no pullup on the collector of the NPN. The cap simply discharges through the 1k resistor when the NPN turns off. It does nothing to aid in the turn off of the PNP.
    It does speed up the ON transition (or at least enhances the positive feedback), but it does nothing for the OFF transition, as I explained above.
    Ron
  4. #4
    Shelton Newbie
    Join Date
    May 2007
    Location
    Brisbane, Australia
    Posts
    12
    Ok - so it is used basically to speed up the on signal for the PNP?
    What is the difference when one connects a cap and a resistor in series compared to when one connects a cap and resistor in parallel - I know they are used in timed circuits, but is there any difference? I not talking about the circuit posted above, but in general terms ?
  5. #5
    Join Date
    Jan 2007
    Location
    Hampshire. England.
    Posts
    10,836
    Blog Entries
    13
    In general terms:
    When a cap/res are in parallel the 'dc' component of the signal is not blocked.
    With a res/cap in series any 'dc' component of the signal is blocked, so the following circuit does not 'see' the 'dc' signal, only the 'ac' signal.
    Commonly used in audio amplifiers.
    This simple explanation does not cover cases where the res/cap parallel or series network is used as a frequency filter.
    For such a simple combination of res/caps in parallel or series, the analysis of circuit can be complex, depending upon many factors, such as frequency, source and load impedances.
  6. #6
    Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent
    Join Date
    Apr 2006
    Location
    England
    Posts
    13,110
    Put simply, at high frequencies the capacitor will act like a short circuit so it will behave like a piece of wire; at DC the capacitor will not conduct so it will behave like a resistor and at intermediate frequencies the resistor and capacitor both come in to play but calculating the impedance is too complex for the average nube.
    if I know the answer.
+ Reply to Thread
Tags for this Thread
