Greetings Electronics Guru's
I have very little knowledge of LEDs and how they work, so please help me if you can.
I have a 1985 GL1200 GoldWing Motorcycle.
I have added LED replacement Light bulbs in all positions with exceptional results except for 1 problem.
This bike has 4 taillights, 2 in the trunk and 1 in each of the 2 saddlebags.
These are tail/brake only as the turn signals are on a separate circuit.
When I put the LED Bulbs in either the trunk lights (2)
Or in the saddlebags (2) with regular filament bulbs in the other 2 they work fine.
But when I put the LEDs in all 4 the problem starts.
They work fine when you first install them; all 4 taillights work great,
But put the brake on to illuminate the brake lights, all 4 brake lights illuminate but the bottom 2 fail to return to tail light mode,
After releasing the brake the top 2 return to tail light mode but the bottom 2 stay on brake light mode.
The LEDs I am using are SMD type 10 SMD per bulb with 7 5mm LEDs on top
I know the amp draw is very low could this be the problem?
Thanks in advance for any help.
Jim
