| | Thread Tools | Search this Thread | Display Modes |
| Experienced Member | I keep seeing this difference amplifier setup: http://hyperphysics.phy-astr.gsu.edu...opampvar6.html But never this one (image attached). It's basically a modified non-inverting amplifier where the reference is a voltage other than ground. Is there a reason for never seeing this circuit and always the first circuit? It seems to me both would work...why does it seem one is usually spoke off and the other one isn't? I need more of a "voltage de-biaser+amplifier" but I'm don't think that's any different from a difference amplifier where one input stays constant. EDIT: It might be important for you to know that I am using a resistive dividier buffered with an op-amp to provide the bias voltage to the - terminal of the op amp. It's to detect motor Back EMF. The back EMF signal is biased at +V/2 (and the back EMF is always positive so the reading is always >(+V/2). WHat I want to do is remove this bias and then amplify it so I am only amplifying the back EMF and not the bias. Last edited by dknguyen : 7th December 2007 at 06:28 AM. |
| Experienced Member | Yes, you did. I'm having trouble understanding why a signal and it's reference with common mode noise is any different from a differential input, since isn't the reference changing the same way the signal is due to the common mode noise to cancel it out? Except...oh wait, the signal isn't being referred to ground rather than the reference, right? Last edited by dknguyen : 20th January 2008 at 04:59 AM. |
| Experienced Member | Quote:
__________________ Ron | |
| Experienced Member | What I mean is, I'm having trouble seeing how non-differential, single ended difference amplifier won't get rid if common mode noise (CMN) if the reference and the signal both have the common mode noise. Won't they cancel each other out during subtraction? (Sig+CMN)-(Ref+CMN) = Sig - REF? |
Ginv=-90k/10k=-9 while the noninverting gain is Gnoninv=1+(90k/10k)=+10. To get the common mode gain, just add these together. Gcm=-9+10=+1 EDIT: Correcting your equation, 10*(Sig+CMN)-9*(Ref+CMN) = 10*Sig - 9*REF+CMN
__________________ Ron Last edited by Roff : 20th January 2008 at 05:23 AM. | |
| Experienced Member | One note on a differential amplifer where common mode rejection is one of the primary goals: the gain of either input with the other input grounded must be exactly the same, and as Ron indicates, the amp will then only amplify the difference between the two signals. In practice, often one of the feedback resistances is made a little smaller by a value of R and a small-value pot with a value of 2R is put in series with it. Then with a common mode signal (same signal fed to both inputs), you adjust the pot for as close to zero signal at the output as you can get. Dean
__________________ Dean Huster, Electronics Curmudgeon Contributing Editor emeritus, "Q & A", of the former "Poptronics" magazine (formerly "Popular Electronics" and "Electronics Now" magazines). R.I.P. |
| Clamp output of op amp | dazza000 | Electronic Projects Design/Ideas/Reviews | 21 | 9th November 2007 08:32 AM |
| PA Amp; noise reduction help | CrazyOldGuy | Electronic Projects Design/Ideas/Reviews | 3 | 18th September 2007 04:46 PM |
| What amp rating do I need? | jtbsc | General Electronics Chat | 4 | 8th September 2007 01:22 PM |
| 40106 variations in manufacturers? Odd performance issue | zevon8 | Electronic Projects Design/Ideas/Reviews | 7 | 30th January 2006 10:21 PM |
| Difference between double sided PCB and 2 layer PCB | darvaish | Electronic Projects Design/Ideas/Reviews | 2 | 10th March 2005 05:32 PM |
