Old 6th December 2007, 05:27 PM   #1
Default Help to identify Capasitor
This board has come out of my Peavey 2XT speaker cab. Seems the capacitors have gone in both speakers and so need replacing but i can find these capacitors anywhere. Can anyone here understand the codes on them and tell me which ones i need to buy (uk) ??
Codes :
XG2I
Mexico
x60
x030
Regards
Craig
craigbeal is offline
Old 6th December 2007, 06:12 PM   #2
I think it is a resetable fuse and not a capacitor
k7elp60 is offline
Old 6th December 2007, 06:32 PM   #3
I would agree, or an overvolts device (MOV?) of some type - not a capacitor.
Old 6th December 2007, 06:56 PM   #4
I like the light bulb as a compressor. It would make music have jerky levels. Speech would have a loud attack at the beginning of each syllable then fade away until the next syllable.
audioguru is offline
Old 6th December 2007, 07:57 PM   #5
It's presumably there only to protect the tweeter?, in case of too much power it drops the level to the tweeter - in normal use it will have no effect, and even in overload it won't have that much. It's a common (and cheap) protection system.
Old 6th December 2007, 08:11 PM   #6
Hope the MOV did its job, but I wonder if what took it out might still be a problem when replaced.
mramos1 is offline
Old 6th December 2007, 08:16 PM   #7
If the level is turned up high enough to cause flickering of the light bulb then the sound from the speaker will also flicker.
Old 6th December 2007, 10:22 PM   #8
Only from the tweeter, as that's all it will feed.
Old 6th December 2007, 10:36 PM   #9
I fear that the MOV is improperly wired. there has to be additional protection to safeguard the board- leave alone the MOV. Had the designer shifted the MOV on to a mechanical screw type mounting the board could have been saved from burning
Now Craigbeal has to somehow salvage it, carving out the burnt portion, manually locating the new MOV elsewhere, and hand wiring it.
Regards,
Sarma.
mvs sarma is online now
Old 6th December 2007, 10:40 PM   #10
I would think you could remove the MOV, make sure the traces are good and see if it still works. If so, replace the MOV if you can find out its voltage.
mramos1 is offline
Old 17th March 2009, 09:07 PM   #11
I have this same problem with this same exact board...I'm wondering if you ever found a suitable replacement for the MOV
2ndserve is offline
Old 18th August 2009, 05:04 PM   #12
We have these available if you need them 01708680971...
Thanks!
ELM is offline
Old 18th August 2009, 05:15 PM   #13
I doubt it's a MOV, it's more likely to be a PTC.
Nigel is correct that the bulb is there to protect the tweeter.
if I know the answer.
Hero999 is offline
capasitor, identify
help identify baudmiksen Chit-Chat 3 20th July 2007 02:06 PM
diode identify engineer0140 General Electronics Chat 5 28th March 2007 03:24 AM
non-polar capasitor value reading yukanti General Electronics Chat 4 23rd February 2005 05:30 AM
Need help to identify component. Please help. bkch0 General Electronics Chat 2 14th June 2004 04:26 PM
how can i designe hardware windows o/s can identify Chinthaka General Electronics Chat 1 22nd August 2003 01:12 AM
