Old 6th December 2007, 03:46 AM   #1
Default Sharing throttle position sensor signal
Hello Everyone,
I need to share the throttle position sensor signal going to the engine ECU with a central differential controller. If I connect both controllers to the TPS (throttle position sensor) the engine ECU reads as it should until I start the engine. Then the TPS value changes by about 1% to 2%.
I have made up this circuit that sort of works. The problem is the voltage into the diff controller is not exactly the same across the 0 to 5 volt signal range of the TPS.
Ray.
rayhall is offline
Old 6th December 2007, 06:16 AM   #2
You need a rail-to-rail input and output op amp, connected as a voltage follower (unity gain, noninverting), that will work with a 5V supply. If you don't know what that means, we can draw a schematic. Can you use surface mount components, or do you need to stick to through-hole parts? Surface mount units are probably easier to find. Maybe one of the guys here can suggest a thru-hole part if you need one.
Ron
Roff is offline
Old 6th December 2007, 06:39 AM   #3
Ron,
Thanks for the reply. Surface mount components are not a problem. I know basic electronics, but most of this statement is a bit over my head. Any help in the right direction would be good.
Ray
rayhall is offline
Old 6th December 2007, 06:45 AM   #4
Originally Posted by rayhall
Ron,
Ray
I'll try to select an op amp for you. What parts supply houses do you have access to? Or, you might be able to get samples from Maxim.
Ron
Roff is offline
Old 6th December 2007, 07:07 AM   #5
Ron,
That would be great..
Farnell, RS Componets and Digi-Key.
Ray.
rayhall is offline
Old 6th December 2007, 05:03 PM   #6
Sorry I disappeared. Sleep intervened.
The TLV2371 appears to be available from Farnell. I didn't check the other vendors. If you can't get it, there are others.
Ron
Roff is offline
Old 6th December 2007, 10:29 PM   #7
Ron,
Thank you...
I am off to make it up. I will report back when it is done.
Ray.
rayhall is offline
position, sensor, sharing, signal, throttle
PIC16F628A Reset? marting Micro Controllers 18 5th December 2008 09:31 PM
Setting stepper motor to 'home' position. MrNobody Micro Controllers 14 3rd October 2007 04:04 PM
Motor Position Control Problem YAN-1 Electronic Projects Design/Ideas/Reviews 10 31st March 2006 03:03 PM
Scooter Throttle Control fantasymick General Electronics Chat 2 28th September 2004 02:36 AM
