+ Reply to Thread
Page 2 of 2
First 1 2
Results 16 to 17 of 17
Thread: curen sink activation of gates
  1. #16
    JoeRandom Newbie
    Join Date
    Nov 2007
    Posts
    8
    Quote Originally Posted by ericgibbs
    Forget the 2nd circuit option, its not going to work as you expect.
    The 1st circuit option looks Ok, but it needs some small changes/additions.
    As you are inputting nominal +12v [15Vpk] square wave signals you cannot directly use standard TTL logic to select the signal destination.
    Can you confirm that the incoming signal frequency is less 500HZ?
    As the Hall effect device is designed for 15V operation and is capable of sinking upto 40mA why are you considering a opto-isolator?
    What are driving with the ignition coil EHT output?
    ok thanks yep the in put is less than 500hz.
    am thinking of using farchild AND gates a well as inwerters
    https://secure.vividcluster.crox.net...ded/ZC4081.pdf
    was not thinking wen sagested opto curlers
  2. #17
    ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent
    Join Date
    Jan 2007
    Location
    Hampshire. England.
    Posts
    10,849
    Blog Entries
    13
    hi joe,
    Those gates look ok to me, just make sure that you protect them from transients greater that +15V. Especially as its close to/working with an ignition coil.
    Post your final circuit when you are ready.
    Link to my Articles: http://www.electro-tech-online.com/a...icgibbs-55450/
+ Reply to Thread
Page 2 of 2
First 1 2
  1. Aluminium for a sink
    By ebuka_2 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 15th September 2007, 11:37 PM
  2. Can a TTL/CMOS Chip Sink Current?
    By buurin in forum General Electronics Chat
    Latest: 12th October 2006, 01:54 AM
  3. Furnace Ignition (simulation/NOR gates) --->Help Please.
    By Melissa9 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 17th May 2004, 01:50 AM
  4. AND, OR, NOT Logic Gates Help
    By LiquidOrb24 in forum General Electronics Chat
    Latest: 9th February 2004, 03:42 AM
  5. Convert Leds to 7 Segment Display
    By Almazick in forum General Electronics Chat
    Latest: 19th August 2003, 07:53 PM
Tags for this Thread
