+ Reply to Thread
Results 1 to 10 of 10
Thread: fluid sensor circuit
  1. #1
    sam12345 Newbie
    Join Date
    Nov 2007
    Posts
    3
    Cool fluid sensor circuit
    I would like some help in designing a sensor circuit (using Darlington transistors?, may be two in series?) that would with couple of probes in a plastic container sense the presence of a non H2O fluid or lack of it. Lack of fluid then would trigger couple of LED s. I have to use ~8 V (1.2V X 8) cells to accomplish the task. Any help is appreciated.
  2. #2
    grim Good grim Good grim Good
    Join Date
    Oct 2006
    Location
    Bedford UK
    Posts
    168
    if the fluid conducts, then just drive the base current through the liquid.
    Drake Transformers Transformer Designer. 1992-1997
    Dagnall Electronics / Clairtronic Transformer Designer. 1997-2009
    Now going it alone
  3. #3
    Leftyretro Excellent Leftyretro Excellent Leftyretro Excellent Leftyretro Excellent
    Join Date
    Mar 2007
    Location
    Hercules, California
    Posts
    1,420
    Quote Originally Posted by sam12345
    You really need to be more specific about what the "non H2O" fluid is. What is it's conductivity specification?
    Some liquids like oil are very good insulators and a current sensing contact type level sensor might not work reliably.
    Lefty
    Measurement changes behavior
  4. #4
    Wingmax Excellent Wingmax Excellent Wingmax Excellent Wingmax Excellent
    Join Date
    Sep 2007
    Location
    Australia
    Posts
    163
    Do some experiments on measuring the resistance of the fluid. Use this resistance as a resistor to bias a transistor. Use another resistor on the base if necessary to adjust to turn the transistor on or off if the fluid is present.
    May the force be with you.
    My project: Simple White Line Follower
    http://au.youtube.com/watch?v=8Z_MmrdH4oc
    http://i271.photobucket.com/albums/j...nefollower.jpg
  5. #5
    Join Date
    Oct 2006
    Location
    Bedford UK
    Posts
    168
    or a float switch
    Now going it alone
  6. #6
    Join Date
    Sep 2007
    Location
    Australia
    Posts
    163
    Quote Originally Posted by grim
    Hope the fluid is not highly flammable.
  7. #7
    sam12345 Newbie
    Join Date
    Nov 2007
    Posts
    3
    Hi all
    Thanks for your time and info.. The fluid that I have in mind is model engine fuel which does contain oil. I know that it will not conduct current as good as water, but it does conduct some current. This is why I need to amplify the current to activate a 5V relay that will light couple of LEDs. Since I am limitted to using 9.6V nicad pack as power source, which Darlington would you recommend for high amplification of the current that will pass through the fuel? Any one brave enough to draw me the basic schematic? Thanks
    Sam
  8. #8
    jpanhalt Excellent jpanhalt Excellent jpanhalt Excellent jpanhalt Excellent jpanhalt Excellent jpanhalt Excellent
    Join Date
    Jun 2006
    Location
    Cleveland, OH, USA
    Posts
    1,589
    Hi all
    Thanks for your time and info.. The fluid that I have in mind is model engine fuel which does contain oil. I know that it will not conduct current as good as water, but it does conduct some current. Sam
    I suspect the conductivity of model aircraft fuel changes with conditions and source. If you are referring to "glow" fuel, I would suggest a capacitance-based method as has appeared on this site several times. One recent discussion was:
    http://www.electro-tech-online.com/g...-computer.html
    Scan down to the post by KMoffett, which includes a schematic. Capacitance probably changes with the fuel composition as well, but capacitance is a well established means for measuring fluid levels. John
  9. #9
    KMoffett Excellent KMoffett Excellent KMoffett Excellent KMoffett Excellent KMoffett Excellent
    Join Date
    Oct 2007
    Location
    Minneapolis MN USA
    Posts
    1,384
    John,
    Thanks for pointing to my circuit. I would have done that earlier, but Sam's original spec's (8v battery and a darlington) almost sounded like a school assignment.
    Sam,
    My circuit was to monitor for an empty plastic fuel line from an aircraft's overhead fuel tank. It could also be used with a plastic "sight tube" outside a container. I just measured some kerosene and naphtha, and got infinite resistance. So, it looks like it's possible to just use two metal probeds directly in the fuel container. Since capacitive sensors are affected by their surroundings, can you describe in detail were and how this "plastic container" is used?
    Ken
  10. #10
    sam12345 Newbie
    Join Date
    Nov 2007
    Posts
    3
    Default fluid sensor
    Hi one and all
    Thanks for showing an interest on my thread. Basically what I have is a 25 ounce plastic container that is filled with model aircraft fuel and located in the fuselage of an RC heli. Normally, to keep track of fuel consumption and prevent fuel starvation, you would reset a clock on your transmitter and fly the thing for so many minutes before landing it, usually 10-12 minutes affair depending on the size of the fuel tank.
    What I am trying to do is design a circuit that would have enough current amplification with 9.6 V pack to overcome the resistance of the fuel. I was successful using a 15 V from a DC power supply, but the added weight would jeopardize the flying characteristics of the helicopter. The question is , what transistor would have a very high gain and operate on 8-9v dc?
    ty all
    sam
+ Reply to Thread
  1. Meaure water temperature inside a sealed pipe
    By kybert in forum Electronic Projects Design/Ideas/Reviews
    Latest: 11th March 2006, 04:48 PM
  2. Electric Heater and FeCl3 Questions: Lots of em
    By DigiTan in forum General Electronics Chat
    Latest: 3rd January 2006, 07:46 AM
  3. OT: Miniature Fluid Pumps
    Latest: 22nd February 2005, 06:50 PM
  4. LM1830 fluid level detector equivalent
    By udi_hakim in forum Datasheet/Parts Requests
    Latest: 25th January 2004, 08:22 PM
Tags for this Thread
