| Experienced Member | hi guys i just a few question about designing a fm transmitter. what are the things that i should consider in designing it. |
| Experienced Member | Quote:
- Licensing. Are you in a region where transmissions are regulated? You may need a licence to operate; you should check that out. - Construction techniques. You won't be able to breadboard it; wire lengths and connection quality are important. - How much money do you have to spend on this? It'll probably be more expensive to build than to buy. What exactly are you trying to do? What are your power requirements? You could try looking up local ham radio clubs. If you find one, get in touch with them and chances are someone will be happy to give you advice. Torben | |
-what frequency will it operate on? - what output power will it deliver? - what kind of antenna will be used with it? - what kind of receiver will be used to receive it? - what power supply will be used? Based on the answers to those questions, others will then come up like: - what bandwidth will my signal occupy, and therefore what frequency deviation will my modulator deliver? - what type of modulator will be required...analog, digital, stereo, subcarrier? - if digital, what protocol or standard will be supported? - what frequency stability will be necessary? - what modulation signal to noise ratio will be met? - what spurious emissions are acceptable? there are many other questions, but these are the basics. FM transmitters are commonly used in broadcasting and two-way communications radios, so it would be helpful if you specified which type you are thinking of as the two types are very different.
__________________ RadioRon | |
| fm transmitter | mns | Electronic Projects Design/Ideas/Reviews | 8 | 9th November 2007 03:41 AM |
| Attempting to make a Keyfob transmitter... | adamthole | Electronic Projects Design/Ideas/Reviews | 7 | 25th November 2006 12:05 PM |
| usb soundcard with fm transmitter | Gideonstk | Electronic Projects Design/Ideas/Reviews | 2 | 14th June 2006 01:31 PM |
| i want help in designing FM transmitter at 26.995 MHz | pradeepubbala | Electronic Projects Design/Ideas/Reviews | 0 | 8th June 2005 09:14 AM |
| Transmitter | zachtheterrible | General Electronics Chat | 3 | 5th August 2004 09:55 AM |
