Old 5th November 2007, 05:04 PM   (permalink)
Default Bridge rectifier temperature
I have a 2W10 bridge rectifier and according to a thermal camera, it is operating at >105 deg C (out of range). I would like to know, is this normal? Assuming it is operating at its rated current, it should dissipate about 1.2*2=2.4W (I believe).
Its max operating temperature is also given as 125 deg C, is this assuming normal load conditions?
The temperature seems fairly high to me, bearing in mind there is no heatsink.
Sorry if this question seems uninformed.
Thanks in advance
stevene is offline
Old 5th November 2007, 05:08 PM   (permalink)
It won't last long if you operate it near its max allowed temperature.
Then when it fails it might cause a fire or wipe out other parts.
audioguru is offline
Old 5th November 2007, 05:23 PM   (permalink)
The overtemp element was one of my initial suspicions. This is work based (hence access to a thermal imager) and I am the only person in the department with ANY qualifications in electronics-albeit a bad one. It is an intermittant recurring fault where a unit shuts itself down, and restarts the PLC process. Seems odd to me for a unit to be operating at a potentially dangerous temperature.
stevene is offline
Old 5th November 2007, 06:15 PM   (permalink)
I would suggest measuring the current it's passing?, in case the load is drawing too much. It's also possible that one diode might be short, although I would expect that to take out a fuse? - but if it didn't, it would get excessively hot.
You might try the 'wet finger test' - lick your finger tip and touch the rectifier with it (obviously being careful about any electrical contact) - if it goes 'hisssss' as the saliva evaporates, it's really running too hot
Who needs thermal imagers?.
Old 5th November 2007, 07:09 PM   (permalink)
Assuming it's operating off <25VAC otherwise I wouldn't recommend touching it, especially with a wet finger!
Screen name: Aloone_Jonez
Hero999 is offline
Old 5th November 2007, 07:29 PM   (permalink)
I woudn't have thought that a rectifier would shut itself down if too hot. It would just go bang.
There may be an overload, which is causing the rectifier to run hot, but some other device overheats and trips a thermal shutdown.
Diver300 is offline
Old 5th November 2007, 11:39 PM   (permalink)
Which was why I said "(obviously being careful about any electrical contact)", doing so on 230V mains is perfectly normal - but obviously for people who know what they are doing!.
bridge rectifier & Capacitor for DC Motor jayt Electronic Projects Design/Ideas/Reviews 16 23rd February 2007 01:34 PM
Question about rectifier bridge wat Electronic Projects Design/Ideas/Reviews 14 1st December 2005 09:48 AM
full-wave bridge rectifier problem MsStateDawg Electronic Projects Design/Ideas/Reviews 12 5th January 2004 07:52 PM
bridge rectifier batman Electronic Projects Design/Ideas/Reviews 2 15th December 2003 05:27 PM
Bridge Rectifier Current Rating -- How much is enough? hamfiles General Electronics Chat 6 6th August 2003 07:15 AM
