Hi guys. Been a while, I know. ![]() I'm building a test-box for a small switch panel that runs on 28vdc and I want to AND two to four inputs so that the output is source voltage (the aforementioned 28vdc) to drive a lamp. Were this device powered by 5vdc, I'd already have the tester together, using a couple quad-AND IC chips. ![]() I wanted to do this with diode logic for simplicity's sake, but ran into a roadblock for two reasons-- up to now I have been using negative logic, and I don't want to create too much of a current draw during the "off" phase. I thought maybe a couple diodes coupled with a FET might do the trick, but frankly, it's been something like twenty years since I did any kind of engineering with a transistor and I'm feeling a little overwhelmed by it. ![]() Can anyone help me?
__________________ http://xs64.xs.to/pics/06030/Banner4.gif | |
The following family of so called peripheral drivers may be of interest to you. They can withstand high voltages at the output. If the sense is wrong then you can certainly use them to drive a PNP high side switch. In either case these are handy little goodies. We used to use them for hammer drivers on line printers. You remember line printers -- right? http://focus.ti.com/lit/ds/symlink/sn75452b.pdf Last edited by Papabravo; 4th November 2007 at 06:19 PM. | |
Thanks, this looks like it might do the trick. As I recall, max load should be less than 300ma. I'll try to find a couple and breadboard a sample circuit next week. Oh, yes, I do remember line printers... still useful when coding-- ribbons last forever and print quality is not an issue when printing out code for editing.
| | #4 | |
Back in those days a high speed drum printer or a dual removable hard-disk drive would cost as much or more then a normal 3 bedroom home Heck the ten high platter blank removable disks cost more the $1,000 Lefty
__________________ Measurement changes behavior | ||
Assuming that the inputs will be 0 or 28V then something like this should work. Mike. Edit, just realised that's a NAND gate. Another stage would fix that. Last edited by Pommie; 6th July 2008 at 05:13 PM. | |
| | #6 | |
Lefty-- I was so glad I didn't have to deal with those 10-packs. I used work on HP 7906 dual drives (one fixed, one removable; 18" platters). Those things crashed on an almost weekly basis and aligning the replacement fixed platter would test anyone's patience. Once I got people to stop smoking in the lab, things quieted down a bit-- those micron filters worked only so much.
__________________ http://xs64.xs.to/pics/06030/Banner4.gif | ||
| | #7 |
Unfortunately, NAND = all hi = lo out. If you switch the diodes around and swap the pnp for npn and reverse the power supply, then you will get all lo = light out, an OR gate. Another transistor stage will give you what you need. Mike. | |
| | #8 |
Hi Dngrsone, Try this. on1aag. | |
| | #9 |
4 relays, with their contacts in series?
__________________ Drake Transformers Transformer Designer. 1992-1997 Dagnall Electronics / Clairtronic Transformer Designer. 1997-2009 Now going it alone | |
| 28vdc, capable, gate, handling |
