| OK, so I've seen on some audio sites that people are using constant current sources on the output of op-amps (but inside the feedback loop) tied to the V- rail. So it will be constantly driving current even with 0V output. They usually do this in headphone amplifiers to avoid any kind of crossover distortion due to the low signal levels. Is there any merit to doing this at all? Is it really class A operation? | |
| Those fools use an OPA2134 dual opamp that has 0.00008% distortion that is so low that it is completely inaudible and is extremely difficult to measure. Then they add a biased load to it so that only one of its output transistors operates in class-A instead of both output transistors operating in class-AB. It might end up with more distortion. It might melt.
To reduce power consumption the output stage was run in class B, so you got cross-over distortion - by forcing the output stage to be single ended, you got a low power, less distorted opamp. However, far easier to use a better opamp in the first place!, and probably better performance as well. | ||
| The old LM324 quad opamp was the first low-power opamp. They reduced its supply current by removing the bias voltage between the output transistors so they operated in cutoff for the middle 1.2V of a signal. The crossover distortion is horrible. Negative feedback doesn't help much to reduce the distortion because the low power opamp has poor high frequency response. Adding a DC load allows one output transistor to operate in class-A. The distortion is 3% when it has 100% negative feedback reducing it. The distortion drops to 0.0018% when the output operates in class-A:
| Told you Audioguru would know! And I got it right as well! - I thought it was the LM324. | |
The old LM358 dual low-power opamp uses the same old opamps as the old LM324 quad.
| Thanks guys! I knew I was doing right asking here. I thought it was quite silly to do using something like the new Burr Brown or Analog Devices parts, but I'm really surprised it actually was legitimately used on an older part. At least now I know where they got the idea My op amp stash consists entirely of OPA2132/2134/NE5532 chips, so I have zero need for this. I've been meaning to get some TL072's just to have, but they shouldn't need this either. | |
| The TL072 is rated at 0.003% distortion. You might hear distortion if it is 67 times more (0.2%).
| biasing problem | salman007 | Electronic Projects Design/Ideas/Reviews | 2 | 11th April 2007 12:13 AM |
| Biasing op amps in class A does it worth it? | hentai | Electronic Projects Design/Ideas/Reviews | 20 | 9th February 2007 10:27 PM |
| What appliance class has a plastic enclosure and an earth connection? | Dave#2 | Electronic Projects Design/Ideas/Reviews | 3 | 9th May 2006 09:11 AM |
| transistor/tube biasing law?? | Learner | General Electronics Chat | 8 | 29th January 2005 12:45 PM |
| how do class D amplifiers work??? | samcheetah | General Electronics Chat | 3 | 13th May 2004 08:32 PM |
