Old 28th October 2007, 04:02 PM   (permalink)
Default An Old Heating Method
Some 20 years ago A friend of mine had this upright room heater that did not heat the air, but rather the people who were near the unit itself. What type of system was this? Were they economical? Do the dissipate much energy when there is no bodies in the room?
iONic is offline
Old 28th October 2007, 04:07 PM   (permalink)
I really think you're dreaming?.
You 'could' do it with microwaves, but killing the people probaby wouldn't be a popular option?.
Old 28th October 2007, 04:23 PM   (permalink)
haha yea the first experimental microwave
my site:www.simons-photography.com
http://rushdenrotaract.org.uk
see also
http://www.bigstockphoto.com/account...fid=m2URATYch5
http://www.redbubble.com/people/simonsphotography
Thunderchild is offline
Old 28th October 2007, 04:34 PM   (permalink)
we used to have one. it wasnt worth a damn.every thing in the room stayed as cold as hell. if you stood in front of it your front would get uncomfartably hot and your rear would be cold. it was called a quartz heater
Gaston is offline
Old 28th October 2007, 04:35 PM   (permalink)
so what principle was it based on ?
see also
Old 28th October 2007, 04:45 PM   (permalink)
Quartz heaters were just radiant heaters, usually only low power and not very effective.
Old 28th October 2007, 04:51 PM   (permalink)
Something that is small and is hot can have a reflector behind it so that the heat is radiated to you if you are in front of it.
They have radiant heating bulbs for washrooms that work like that. They use a lot of power but not as much as heating all the air.
Insulate your house so that a little amount of heat stays there.
Seal all the cracks.
audioguru is offline
Old 28th October 2007, 05:23 PM   (permalink)
Thank You Gaston for keeping me from checking into the idiot hospital!
M thought was that it might work better that a electric space heater. Ya see, I have Polio and what comes "free without charge" is very cold feet. I am normally comfortable everywhere else, but the feet are freezing. I've looked at electric socks, but they are so very sparse in the ankle area when it come to wiring. The heat is mostly concentrated in the sole of the foot. I even wrap my lower legs with fleece with some help, but not enough. If not the Quartz Heater, than maybe someone would like to help me design a foot/lower leg electric warmer device.
Maybe I could get it to run on propane or natural gas!!! (joke!)
iONic is offline
Old 28th October 2007, 07:04 PM   (permalink)
They're called infrared heaters and are used more for curing resins than heating people nowadays.
Screen name: Aloone_Jonez
Hero999 is offline
Old 28th October 2007, 07:25 PM   (permalink)
They're used all the time in the transit centres here.
dknguyen is offline
Old 28th October 2007, 07:30 PM   (permalink)
They're 100% efficient at heating the room.
The problem is that power out of a 110V outlet is limited to around 1500W or so, which won't heat up a room really, and electricity is expensive relative to gas.
The radiant nature can make its effect fairly pleasant for the wattage but it's a limited effect.
They work by releasing a lot of their energy as a ton of invisible infrared radiation. Lots of IR is present in sunlight but this wavelength can't give you a tan or sunburn. When the IR hits something, it turns to heat like sunlight does.
Oznog is offline
Old 28th October 2007, 07:56 PM   (permalink)
I think that's fairly optimistic?, they don't waste energy creating visible light, but the ones I've seen never seem very effective?. In my experience by far the most effective are fan heaters.
That's only in countries with 110V mains, the UK 230V mains gives 3000 watts from a normal socket.
Old 28th October 2007, 08:35 PM   (permalink)
They are 100% efficient at heating the room, any heating appliance is.
The difference is that they are better at heating small areas than fan heaters and convection heaters which isn't any good if you want to warm the whole room rather than just one object.
Here in the UK we can get 3000W from a single socket which is more than enough to heat a reasonable size room.
Hero999 is offline
Old 28th October 2007, 08:47 PM   (permalink)
They're useful in a large warehouse environments or outdoors where it's not practical to heat the air, a well aimed radiant heater will heat the objects/people they're pointed at very efficiently. And they do make gas powered radiant heaters. A 125,000 BTU radiant heater (only 200$ US) will give a bit more than the equivalent of a 36,000 watt radiant electric heater. A quick google search and you'll even find ones that mount on posts to heat patios on cool fall days. A fan heater would be completly useless in those applications.
straight answer, har har."
Sceadwian is offline
Old 28th October 2007, 09:09 PM   (permalink)
I suppose it's like standing in front of a bonfire, the radiated heat warms you rather than the air.
Hero999 is offline
Transformer heating nikhil arora Electronic Projects Design/Ideas/Reviews 34 14th July 2006 01:20 PM
Effects of Electric Frequency on heating Electrix General Electronics Chat 7 8th November 2005 08:29 PM
a new PCB manufacturing method wanted mstechca General Electronics Chat 47 6th August 2005 07:11 AM
third method of SSB generation (weaver's method) samcheetah General Electronics Chat 2 3rd March 2005 10:51 AM
diy etching tank - any ideas for heating? spyghost Electronic Projects Design/Ideas/Reviews 6 5th May 2004 02:01 PM
