Old 31st October 2007, 08:49 PM   (permalink)
don't worry guys it does not confuse me i am familiar with the energy storing/dissipation of electronic components. i was trying to connect theory and practice..
by the way here is another question. still in the application note provided by microship, the authr chose to use a pwm frequency 5 times higher than the one of the orriginal signal.. could i use a frequency 20 times higher? or more? on what basis do we chose the frequency of the PWM signals ?
As far as i understand, the higher the better.. right?
thx
Ibrahim Kamal
check my electronics and robotics page: http://www.ikalogic.com/
ikalogic is offline   Reply With Quote
Old 31st October 2007, 10:24 PM   (permalink)
It really depends what you're wanting to do?, if you're only wanting a DC voltage, without any fast changes, you can have a cutoff frequency MUCH lower than 1/5th of your PWM frequency. But assuming you're using PWM for an amplifier, and you're wanting the filtered output to have a good frequency response (say 20KHz for audio), then using 100KHz for the PWM makes sense, as running it higher may require more expensive transistors, more complicated circuitry, and bigger heatsinks (higher frequency, higher losses).
But if the filter is entirely removing the PWM frequency, then increasing the PWM frequency won't have any helpful effect.
Old 3rd November 2007, 12:03 AM   (permalink)
The accuracy of the output signal will be dependent upon the speed at which the original signal is sampled. A sampling rate 5x that of the original signal frequency will yield good results on the output. If there is any higher frequency content in the original signal, then this information will likely be lost.
Just out of curiosity, what is the purpose of using pwm to recreate the signal? Is this a buffer of some type? If so, then for low power, an op-amp would easily suffice and have low output impedance. If you're taking a signal and looking to significantly boost the power of the signal, then you may want to look into an LC filter to recreate the original signal from the pwm version.
Using an RC filter will require that the output be tied to a high impedance block so that the output impedance is not altered.
OutToLunch is offline   Reply With Quote
Can you help me for Isolated DC to DC gbmewada General Electronics Chat 7 15th October 2007 07:00 AM
Help: Mains Powered DC Motor bobledoux Electronic Projects Design/Ideas/Reviews 4 10th October 2007 09:30 PM
PWM control of BLDC motors (brushless DC motors) jhanus Micro Controllers 6 1st October 2007 04:32 PM
Writing measured voltages to LCD Tamil.selvam Micro Controllers 1 5th September 2006 11:47 AM
Practically converting AC voltages Scubasteve Electronic Projects Design/Ideas/Reviews 5 9th April 2003 01:05 PM
