+ Reply to Thread
Page 1 of 3
1 2 3 Last
Results 1 to 15 of 31
Thread: 555 Dark Detector Circuit Help
  1. #1
    Suraj143 Newbie
    Join Date
    Jan 2007
    Location
    South Mald Isld
    Posts
    924
    Question 555 Dark Detector Circuit Help
    I have this circuit. When dark is applied to the LDR, the output LED will light up.
    I tried with many opamp’s but I’m not satisfied with their performance.
    I need a 5V output when dark is applied. Also it must be very sensitive. The output must not float in between 0V to 5V. It must directly show logic 5V or 0V.
    Can you please see this circuit whether it’s ok or not.
  2. #2
    ljcox Good ljcox Good
    Join Date
    Dec 2003
    Location
    Melbourne Australia
    Posts
    2,446
    I would use a Schmitt Trigger.
    You can make one either from an Op Amp (or Voltage comparitor) or use a CMOS Hex Schmitt Inverter such as the 40106.
    I suggest that you post the circuit of the Op Amp one that you are not happy with so we can analyse it and suggest imprevements.
    What was the issue that you were not happy with?
    Len
  3. #3
    Suraj143 Newbie
    Join Date
    Jan 2007
    Location
    South Mald Isld
    Posts
    924
    I need to operate from 5V.
    When I use an op amp when in ambient light the output led goes dim not giving 5V or 0V. I used a hysteresis too but still the problem is there.
    Here is the circuit i replaced LM358 instead of 741.
    http://www.uoguelph.ca/~antoon/circ/sensor2.htm
    But this 555 circuit the led wont dim its giving 5V or 0V.
  4. #4
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,879
    Didn't you look at the datasheets for the 555, the 741 and the LM358?
    The output low of an ordinary 555 is +0.1V when its load current is low. Its output high is +3.6V.
    Many 741 opamps don't work if their supply voltage is less than 10V.
    If you found a 741 that works with only 5V then its output low is +1.2V and its output high is +3.8V wothout load current.
    The LM358 works when its supply is as low as 3V.
    With a 5V supply its output low is 0V or +1.0V depending on its load current.
    Its output high is +3.8V without load current.
    You need a Schmitt trigger or a circuit with hysteresis to switch quickly when it gets dark.
  5. #5
    Suraj143 Newbie
    Join Date
    Jan 2007
    Location
    South Mald Isld
    Posts
    924
    Hi audioguru thanks for your very useful information’s. Do you have some Schmitt trigger circuits? I have never built one like that.
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,879
    About 45 years ago I made Schmitt trigger circuits with 2 transistors. Look in Google. Cmos Schmitt trigger inputs on inverters and gates are used now.
  7. #7
    Suraj143 Newbie
    Join Date
    Jan 2007
    Location
    South Mald Isld
    Posts
    924
    What about making a Schmitt trigger by using 555 like in the attachment.
    What I need is to add the LDR & transistor circuit to this circuit to give 5V or 0V in the output.
  8. #8
    Join Date
    Dec 2003
    Location
    Melbourne Australia
    Posts
    2,446
    If you want it to operate on 5 Volt, there are at least 3 solutions.
    1. use a 74HC14 Hex Schmitt Trigger IC. This has enough current source and sink capability to drive a LED. This solution requires the least number of components. But don't neglect to connect the unused inputs to gnd.
    2. Use a Voltage Comparitor IC such as the LM311 configured as a Schmitt Trigger. It has a transistor output that will drive the LED, see the data sheet for details.
    3. Use an Op Amp that can operate from a single 5V supply and use an N channel MOSFET (such as the 2N7000) to drive the LED.
    Options 3 & 3 have the advantage that you can set the hystersis according to your need. Whereas, in the case of option 1, the hystersis is set inside the IC.
    Len
  9. #9
    Join Date
    Dec 2003
    Location
    Melbourne Australia
    Posts
    2,446
    Quote Originally Posted by Suraj143
    There is a Schmitt Trigger inside the 555. But the problem is that the hystersis is set inside the 555 to about one third of Vcc. This is probably too wide for your situation.
    Len
  10. #10
    Suraj143 Newbie
    Join Date
    Jan 2007
    Location
    South Mald Isld
    Posts
    924
    Hi ijcox thanks for your suggestions. I like your first method.
    The 74HC14 Hex Schmitt Trigger IC.
    What about the input side? I need only a V/R & LDR is that right?
    & the output I can connect to a led via resister?
    Join Date
    Dec 2003
    Location
    Melbourne Australia
    Posts
    2,446
    Without looking at the Op Amp's data sheet, I suspect that the Op Amp does not switch to a low enough voltage to switch the transistor off. That's why I suggested you use an N channel MOSFET in a previous post.
    There is no hystersis in this circuit. You need a resistor from the output of the Op Amp to the + input. But it won't operate at 5 Volt.
    I don't understand your last sentence. It does not make sense.
    Len
  12. #12
    Join Date
    Dec 2003
    Location
    Melbourne Australia
    Posts
    2,446
    What about the input side? I need only a V/R & LDR is that right? Yes
    & the output I can connect to a led via resister? Yes
    However, as I said in my original post, the hystersis may be too wide since it is set inside the IC.
    You could possibly solve this by applying some negative feed back.
    This would require another Schmitt Trigger (you have 5 spares in the IC) with its input connected to the output of the first one. Connect a resistor from the output of the second to the input of the first. I have not done the calculations, but I expect that this will reduce the hystersis.
    EDIT
    I made an error in the above.
    You don't need a second Schmitt, just connect the feedback resistor from the output of the first to its input. set the value of the resistor to give the hystersis that you need.
    Len
  13. #13
    Suraj143 Newbie
    Join Date
    Jan 2007
    Location
    South Mald Isld
    Posts
    924
    Quote Originally Posted by ljcox
    Hi ijcox when I’m testing the LM358 I added hysteresis to the wrong pin.
    I replaced the Rh (feedback resister) to the output pin & to the (-) inverting pin which is connected to the LDR.
    I’ll give a try to place that resister to the out & non inverting pin.
    But the original circuit gives that to the inverting pin.
  14. #14
    Join Date
    Dec 2003
    Location
    Melbourne Australia
    Posts
    2,446
    Note the edit to the previous.
    Len
  15. #15
    Join Date
    Dec 2003
    Location
    Melbourne Australia
    Posts
    2,446
    Hystersis requires positive feedback. So the feedback resistor must go from the output to the + input.
    Len
+ Reply to Thread
Page 1 of 3
1 2 3 Last
  1. 555 timing periods.
    By wombweller in forum Electronic Projects Design/Ideas/Reviews
    Latest: 20th October 2007, 05:31 PM
  2. Anyone experimented with minimum pulse with 555?
    By chadj2 in forum General Electronics Chat
    Latest: 12th October 2007, 01:19 AM
  3. 555 Alarm!
    By Krumlink in forum General Electronics Chat
    Latest: 6th October 2007, 10:47 PM
  4. dark detector
    By ctgroup in forum Chit-Chat
    Latest: 11th July 2006, 09:36 AM
  5. how can I indentify a transformer
    By glmclell in forum Electronic Projects Design/Ideas/Reviews
    Latest: 28th September 2004, 03:26 PM
Tags for this Thread
