Old 21st October 2007, 09:15 AM   (permalink)
Default Switching AC
Is there any device, like a relay, that can switch AC quickly?
Sort of like transistor like behaviour?
ScuzZ is offline
Old 21st October 2007, 09:31 AM   (permalink)
A solid state relay?
speakerguy79 is online now
Old 21st October 2007, 10:43 AM   (permalink)
If you are after a solid state relay, try searching on TRIAC. Here is one of the first hits I got:
http://www.uoguelph.ca/~antoon/circ/solidstate.html
Your question implies that a conventional relay will suffice, but for some reason you believe they only work on DC. AC relays are very commom.
John
jpanhalt is online now
Old 21st October 2007, 04:41 PM   (permalink)
A relay will do it. BUt if you need something like an "AC MOSFET" that can switch at high speeds, you need a triac or an alternistor (and it might be easiest to get an triac driver IC as well since they switch a bit more complicatedly than a MOSFET).
dknguyen is offline
Old 21st October 2007, 04:58 PM   (permalink)
How much AC current and voltage are you trying to switch?
For high power line voltage AC loads, you would use a triac.
If you want to switch low level AC audio signals, then there are IC's that do this with minimum distortion. You can also build your own AC "switches" out of FETs.
kchriste is offline
Old 21st October 2007, 10:03 PM   (permalink)
Perhaps you might try asking what you really want?, your current question is completely meaningless.
Old 23rd October 2007, 11:02 AM   (permalink)
I was just wondering whether there was another way to switch AC on and off quickly.
Something that would be easier to use and would not need protection diodes etc.
Switching AC at 240v 15Amps.
It was just a general question, I wasn't chasing any specific information.
Just as a relay will allow you to use DC to switch AC current and is isolated from the AC current to a point; will a TRIAC allow the same?
ScuzZ is offline
Old 23rd October 2007, 11:37 AM   (permalink)
It seems your "general question" has been answered. There are two categories of device, solid state and mechanical. Mechanical would be a relay, and they are readily available. Solid state would be something like a triac-based relay as suggested already.
Your comment that you want, "Something that would be easier to use and would not need protection diodes," seems inconsistent with your request for general information.
Where did you get the idea for needing protection diodes? Whatever you used needs to be designed properly, but since you have no specific use in mind, it is impossible to say what the design will need.
If you are just going to switch 240 V at 15A for something like a motor, I would use a standard starter switch or starter relay designed for motor use (check out industrial supply places like McMaster Carr). A simple on/off switch that is properly rated will work fine. You probably do not need a low-voltage control, unless it is for an industrial application. John
Old 23rd October 2007, 12:15 PM   (permalink)
There is another category of device, a hybrid one.
I have several "module" that look like solid state devices. It is labelled as "Solid State Relay" and manufactured by company "Gordos Arkansas". But when I cut one open, it actually uses a reed switch to operate a component which looks like a TRIAC.
L.Chung
eblc1388 is offline
Old 23rd October 2007, 09:59 PM   (permalink)
Thanks for the correction. One must always consider the hybrid -- like steam ships with sails.
On a lark, I did a search on Gordos Arkansas. Apparently, the part is obsolete and was made so long ago, the term "solid state" was more popular than "hybrid."
John
Old 23rd October 2007, 10:05 PM   (permalink)
So just like a mechanical relay can use DC to switch high AC.
Will a solid state relay allow the same?
Protection diodes -> to allow the surge from a collapsing electromagnetic field to flow, reducing or eliminating the chance of damaging components.
And adding to the original question: If you use any of these components, do you get a 'bounce' ?
ScuzZ is offline
Old 24th October 2007, 07:41 AM   (permalink)
Yes, except there is no electrical moving contact carrying load current. Depends on different construction by various manufacturers, some can also switch DC loads. The ones I mentioned above can switch an 240V AC load upto 30A.
There is no moving part so there is no bounce. It can be used straight away on common AC loads. With difficult loads like high inductance, one must refer to the manufacturer datasheet to see if additional external components are needed to ensure correct operation.
L.Chung
eblc1388 is offline
AC Power Supply Musepro General Electronics Chat 1 5th September 2007 08:07 PM
Linear Vs Switching Regulation. Overclocked General Electronics Chat 35 14th January 2007 04:25 PM
Zero Signal audio switching gtrdude General Electronics Chat 12 12th November 2006 07:27 PM
Simple PNP switching problem DirtyLude Electronic Projects Design/Ideas/Reviews 41 8th October 2006 02:20 PM
HID ballast/LCD projector switching spark gap symptoms linuxglobal General Electronics Chat 5 1st April 2006 06:16 AM
