+ Reply to Thread
Results 1 to 14 of 14
Thread: can a 1.5 button battery be used in a normal 1.5v LED flasher project
  1. #1
    dih
    dih is offline
    dih Newbie
    Join Date
    Oct 2007
    Posts
    5
    Default can a 1.5 button battery be used in a normal 1.5v LED flasher project
    i need to make a small LED flasher and i've read many 1.5v project. is it possible to use a button battery? is there any circuit diagram that i can use? emergency.. i need it fast
  2. #2
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,794
    You could use a button battery, as long as it's able to supply enough current?, but bear in mind it won't last very long, they only have a very small capacity. Google for "joule thief" for circuits.
  3. #3
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,879
    There is no such thing as a "1.5V " LED. It might be 1.3V and burn out with a 1.5V supply or it might be 1.8V and not light with a 1.5V supply.
    LEDs are driven with current, not voltage. Usually a current-limiting resistor is in series with an LED (or the internal resistance of a tiny battery) and the supply voltage is higher than the LED's max voltage rating.
    I sketched the voltage stepup circuit for my solar garden light and added a flashing circuit to it. It will work with a 1.5V LED or a 3.5V LED when the battery voltage is less than 1.0V.
    EDIT: Added a transistor to isolate the voltage stepup circuit from the flasher circuit and to make the LED blink briefly instead of pause briefly.
  4. #4
    Krumlink Excellent Krumlink Excellent Krumlink Excellent Krumlink Excellent Krumlink Excellent
    Join Date
    Aug 2007
    Location
    Michigan, USA
    Posts
    2,093
    Blog Entries
    1
    This is a great example that current drives a LED, not voltage:
    http://www.youtube.com/watch?v=roPJosBqsXA
    IF YOU WANT TO HELP FINE IF NOT PLEASE DON"T PEE IN MY CHEERO'S
  5. #5
    Oznog Excellent Oznog Excellent Oznog Excellent Oznog Excellent Oznog Excellent
    Join Date
    Apr 2004
    Location
    Austin, Tx
    Posts
    2,766
    Most LED projects use 3x of the 1.5v button batts because 1.5v isn't enough to light common LEDs. 2x (3v) can light red ones but there's not much headroom voltage for a ballast resistor to stabilize the current.
    The 3V lithium "coin" batteries get used a lot without resistors in flashlights, because the battery's output resistance is itself high enough to limit the LED current.
  6. #6
    Join Date
    Aug 2007
    Location
    Michigan, USA
    Posts
    2,093
    Blog Entries
    1
    That is why they are also in computers as backup memory, since it has high enough ESR.
  7. #7
    Join Date
    Apr 2004
    Location
    Austin, Tx
    Posts
    2,766
    Quote Originally Posted by Krumlink
    ? A backup memory has no use for a high ESR. Very few apps actually desire a high ISR, the tiny LED flashlight thing is a very unusual case.
    Lithium coins are good for holding backup memory because the app can tolerate high ESR batts ok.
  8. #8
    kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent
    Join Date
    Jul 2006
    Location
    Victoria BC, Canada
    Posts
    3,681
    The main reason Lithium batteries are used for memory backup is their extremely low self discharge rate. Since the CMOS memory chips draw next to nothing while in standby, it is really the "shelf life" of the battery that determines how long it will last in this application.
  9. #9
    Help us help you blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent
    Join Date
    Jan 2007
    Location
    Toronto, Canada
    Posts
    10,711
    Blog Entries
    5
    Too bad the old LM3909 isn't made anymore. Radio Shack used to sell the IC. Here's a site that built it without the IC.
    http://home.cogeco.ca/~rpaisley4/LM3909.html
    Bill
    Smart Kits build Smart People
  10. #10
    Join Date
    Jul 2006
    Location
    Victoria BC, Canada
    Posts
    3,681
    BlueRoom, that's a really good example for noobs. Who needs Eagle anyway?
  11. #11
    Join Date
    Jan 2007
    Location
    Toronto, Canada
    Posts
    10,711
    Blog Entries
    5
    I can't take credit for it, just something I found and about 20yrs ago I built a LM3909 flasher when you could actually buy the IC.
    I've added their site to my links page
    Bill
  12. #12
    bobledoux Okay
    Join Date
    Jul 2006
    Location
    Near Salem, OR, USA
    Posts
    127
    I tape the leads of a bright LED to the sides of a 2016 lithium cell. This assembly is inserted into a balloon then filled with helium; used to measure wind speeds at night.
  13. #13
    whiz115 Good whiz115 Good
    Join Date
    Jan 2007
    Location
    DotGR
    Posts
    699
    these days we have led flashers all in one...
    if we don't need it to flash in a special way..there is no need for circuits...
    just a led flasher does the job
  14. #14
    Join Date
    Aug 2007
    Location
    Michigan, USA
    Posts
    2,093
    Blog Entries
    1
    To make it easy, just tape a few button cells together to get about 4.5 V and then put a Flashing LED connected up to it, and now you have a flasher, the easiest you could possibly think of.
+ Reply to Thread
  1. Small Alternating LED Flasher
    By Technoboots in forum Electronic Projects Design/Ideas/Reviews
    Latest: 21st October 2007, 05:56 PM
  2. My first LED project :D
    By mike_302 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 3rd October 2007, 12:02 AM
  3. Electronics 101 Help, LED project
    By ReallyConfuzed in forum Electronic Projects Design/Ideas/Reviews
    Latest: 11th September 2007, 06:38 PM
  4. odd project, 1 button adds a light 1 button takes a light away with sound.
    By KevinAlaska in forum Electronic Projects Design/Ideas/Reviews
    Latest: 6th June 2007, 04:38 AM
  5. Battery Zapper Project
    By jaxart in forum Electronic Projects Design/Ideas/Reviews
    Latest: 9th August 2004, 11:18 PM
Tags for this Thread
