Old 12th October 2007, 08:17 PM   (permalink)
Default Home heater repair
Working on a project in my garage we had a small oil heater plugged into an extention cord and melted the orignal wiring, im replacing the wire but i lost my notes on how it was connected and was hoping someone here could figure it out. Heres a picture that explains most of it.
demitrix is offline
Old 12th October 2007, 09:16 PM   (permalink)
Is that "the incredible heat machine"? It looks just like the one I have.
I have no idea how to connect the wires though. All thats in the picture is wire and connectors, there is no way for any of us to see what goes where.
This message transmitted on 100% recycled electrons
Andy1845c is offline
Old 12th October 2007, 10:21 PM   (permalink)
Its a delonghi, all three wires run into the heater. There are the two on off switches with three prongs each and the dial at the top.
when the switch si turned on it connects the top and middle prongs.
demitrix is offline
Old 12th October 2007, 11:19 PM   (permalink)
As you say, i'm "figuring it out". It may be the right way to connect it, but it may not.
The thing that appears at the top of your 3rd photo is the thermostat. The big terminal at the end of the black wire with a blue wire attached should connect to it.
Then the two terminals with brown wire should go to the middle prongs of the switches.
Do the shitches light up when they are on? If so, the bottom prongs may be the other side of the indicator light. If that is the case, the two blue wires connect to them.
The wire you got uses the european / international color code:
Brown = Live
Blue = Neutral
Yellow + green = Safety ground.
Of course, there also should be a yellow + green (or it may be only green or even bare) ground wire that connects to the heater's chassis
BE SHURE YOU CONNECT THE CHASSIS TO GROUND
E Cerfoglio
Buenos Aires
Argentina
ecerfoglio is offline
Old 12th October 2007, 11:22 PM   (permalink)
You know actually that sounds right...i had originally drawn out the connections but that got lost. There isnt a ground the original plug was 2 prong
I guess i shouldve taken a larger picture but the two wires in the 2nd photo are directly connected to the plug.
demitrix is offline
Setting stepper motor to 'home' position. MrNobody Micro Controllers 14 3rd October 2007 04:04 PM
Expensive repair Wingmax Chit-Chat 12 22nd September 2007 03:48 PM
water heater with temperature controller jemilsan Electronic Projects Design/Ideas/Reviews 27 1st March 2007 07:14 AM
Is TV repair a dead trade? ThermalRunaway General Electronics Chat 16 17th April 2005 09:28 AM
concerning charecteristics of resistive heater Ramesh Babu Adari Feedback/Comments 0 25th February 2004 02:39 PM
